compresion test
Old May 14, 2011 | 12:45 PM
84-6.9L's Avatar
84-6.9L
Could be and injector, Start cracking lines until the miss is found then have that one pop and spray tested
Old May 14, 2011 | 02:20 PM
axel 56's Avatar
axel 56
I did the injectors and I had 12 of 16 test ok and num 8 cyl is alittle low on compression I am going to pull valve cover and check for a broken valve spring before I pull head off
Old May 14, 2011 | 08:07 PM
axel 56's Avatar
axel 56
I picked up a snap on comp tester for diesels today so I am going to do another test the way it says to in the kit with the eng warmed up I will have the numbers up maybe tomoro nite
Old May 14, 2011 | 09:52 PM
fellro86's Avatar
fellro86
Originally Posted by FORDF250HDXLT
That is the injector opening pressure, fuel pressure...
Old May 14, 2011 | 10:05 PM
axel 56's Avatar
axel 56
I used the 8 that came close to 2000 psi on the tester
blueline970
Oct 3, 2012 09:55 PM
Aireeek
25
May 12, 2008 10:19 PM
kevbits
Nov 13, 2007 08:22 PM
jenmarent
Mar 25, 2006 02:31 PM
Lukkys
Jul 24, 2003 06:51 PM
