excursion tank dimensions.
Old May 5, 2011 | 09:49 AM
rat49f6's Avatar
rat49f6
Anyone have pics and dimensions for a excursion fuel tank also what's the going rate for one?
Old May 5, 2011 | 11:38 PM
Ziggy.'s Avatar
Ziggy.
I got mine for $125 which I believe is a tad cheaper than most places, I will call you with dimensions tomorrow.
If you are thinking about using one for your truck, go ahead and scratch that, it will be below the frame.
This pic is with it mounted up against the bottom of the bed. This was with my 4'' lift.
Old May 6, 2011 | 11:55 AM
F-250 Super Duty's Avatar
F-250 Super Duty
I'm thinking about going that route for my Veggie conversion.....
Old May 6, 2011 | 11:59 AM
william_04_x's Avatar
william_04_x
Here's a pic for ya.
Old May 6, 2011 | 12:06 PM
F-250 Super Duty
Jim, you'll have to cut a hole in the bed to make that fit.
Why don't you just plate off the top and bottom of the opening and make that the tank. You would have to bring the bottom plate up a 1/2" so it wouldn't drag the ground.....,
Old May 6, 2011 | 12:36 PM
rat49f6's Avatar
rat49f6
The bed floor will be raised to with in 8" of the bed rails soil should have the height between the frame e and bed rails
Old May 6, 2011 | 03:01 PM
rat49f6's Avatar
rat49f6
William what wheels are those in ur avatar??
FJones8668
Dec 28, 2015 03:50 PM
BigBlueCat
Sep 14, 2015 07:07 AM
pns112500
1947 and Older Ford Trucks
Aug 21, 2015 11:27 PM
Drewski 2
15
Jan 9, 2015 11:35 AM
4x4ford33
Feb 20, 2014 12:19 PM
