Crazy Steering Problem
Old May 5, 2011 | 01:50 AM
scoug001's Avatar
scoug001
Hey guys,
I have a 93 F150 4x4. A couple months ago I got 4.56 gears on my truck. I also had them replace the ball joints and axle pivot bushing because my tires were pointing outward. It fixed it for the most part. But now, every so often, my steering goes haywire. Its happened 5 or 6 times now. Usually when it happens when backing out of a parking spot while cutting the wheel sharp. The truck starts pulling really hard to the right. I have to hold the wheel almost 90 degrees to the left while driving. It'll stay like that for maybe a mile or two then go back to normal if i make another sharp turn or back into a spot, turning the wheel hard. Doesn't always fix it though, it'll go back to normal randomly. Very confused and frustrated.
Steering linkage/tie rods all new- I did them last summer.
Thanks guys.
Old May 5, 2011 | 02:04 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Sounds steering box related to me....Just my .02......Have you checked how much play is in the steering wheel?
Old May 5, 2011 | 02:58 AM
scoug001's Avatar
scoug001
there's some play in the steering wheel but not much. Less than before I did the tie rods and stuff.
Old Jun 7, 2011 | 05:13 PM
cpettymore7777's Avatar
cpettymore7777
i maybe the axle u-joints are sticking
Old Jun 7, 2011 | 05:21 PM
nstueve's Avatar
nstueve
Did you take it to an alignment shop to have the toe-in done after you replaced the tie rods?
x2 on the steering box idea for now...
Does the steering get harder like you loose pressure from the PSP when you have this problem?
Old Jun 7, 2011 | 06:04 PM
Edgethis's Avatar
Edgethis
Is the truck lifted? Oversize tires? I would prolly recommend flushing the PS system with fresh fluid.
Old Jun 9, 2011 | 08:43 AM
nstueve's Avatar
nstueve
I always remind people at this point that our PSP's take ATF (type F) not power steering fluid...
Old Jun 10, 2011 | 03:03 AM
scoug001's Avatar
scoug001
the truck has a 6 inch suspension lift with 35 inch tires.
it was aligned by the same shop after the tie rods were replaced then again after the ball joints were replaced.
the steering does not get harder when it happens, except for the fact that its pulling so hard to the right.
Thanks.
Old Jun 10, 2011 | 06:24 AM
bashby's Avatar
bashby
A sticking axle joint can cause that, turn the wheels to one side then rotate the front axles at the u joints to check for binding.
Old Jun 10, 2011 | 07:43 AM
tjc transport's Avatar
tjc transport
i ain't rite
also check the radius arm bushings.
Old Jun 19, 2011 | 01:16 PM
thrillbillydlux's Avatar
thrillbillydlux
I am having similar issues on my 1992 f150 5.8 with 33" tires 4" lift. I checked everything on it for play with the front end of the ground and checked the wheel bearings. I was wondering how to tell for sure the steering box is shot and how to check a salvaged one from the scrap yard. Or would it be one of those things that would be better to get remand/new.
Old Jun 20, 2011 | 10:44 AM
nstueve's Avatar
nstueve
I'm not sure how to diagnose a bad steering box, but I just rebuilt Thumpers box last year to try and solve irratic steering problems I was having. They are pretty easy to do and if you watch PowerBolck I think they just did a how to on rebuilding steering boxes. Anyway, steering boxes can be fixed and/or rebuilt... seal/rebuild kits can be had for $30-$60. I will admit they are tricky to do if you aren't meticulous with details. Leaks are prevelant with home rebuilds...
Here is a 73-79 write up... they are talking about a different gear box but some of the information transfers to our trucks.
https://www.ford-trucks.com/forums/5...build-kit.html
Here's a link to some good rebuild kits! they come with good instructions if you feel ambitious to try it yourself.
1980-96 Ford Truck/bronco - Steering - Steering Box
Rockauto and Amazon should have gates and edelmann kits as well... but haven't used them before.
IT_Dude
Jan 8, 2018 12:27 PM
warrens250
41
Mar 5, 2017 03:50 AM
XLnAK
Sep 6, 2015 12:06 PM
santacruzf250
Jun 17, 2009 12:06 AM
4.0 Beast
Nov 16, 2008 03:04 PM
