Turbo compressor outlet flange
Old May 5, 2011 | 12:44 AM
rusty9cab's Avatar
rusty9cab
Does anyone know what kind of flange that is on the turbo compressor outlet? It appears to be some type of v band flange or the like. I am attempting to intercool my truck and I was able to get a banks twinram inlet but not the compressor outlet. I am just going to build one, because banks wants more than I want to spend for the part. I have seen where people have carefully removed the flange on the stock intake and used that, but I would like to keep it intact in case I want to put the truck stock again. I have also had a hard time finding the stock inlet on the internet. Thanks.
Old May 5, 2011 | 04:47 AM
Cuda_jim's Avatar
Cuda_jim
If you are asking of the exhaust outlet it's a Marmon Clamp that holds it together.
Old May 5, 2011 | 10:47 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
With the Banks Im pretty sure you can use the OEM marmon clamp(v clamp) but if you buy or use an early 99 Y pipe, you need a different (a little wider) marmon clamp.
Old May 6, 2011 | 08:01 PM
rusty9cab's Avatar
rusty9cab
This is the flange I am talking about on the stock intake. I know you can buy the E99 spyder and it will bolt right up, but I got the Banks twin ram for next to nothing and can't see spending 100 to 125 bucks on the spyder right now. I figured some turbo company might sell just the flange, I'm just not sure the exact type of flange. Thanks guys.
Old May 6, 2011 | 08:40 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Let me see if I understand well, do you have the grey pipes in the pic?, if so, you can use the OEM marmom clamp and the left pipe has the flange already. or am I confused?
Old May 6, 2011 | 08:57 PM
bad12jr's Avatar
bad12jr
The way I understand it he has the cold side and needs to make the hot side. Doesn't wanna butcher his stock y for the flange.
I don't know where to get the flange.
Old May 6, 2011 | 09:58 PM
rusty9cab's Avatar
rusty9cab
That's right, I have the cold side. There was a write up I saw a while back on one of the sites where the guy ground the flange out of the stock intake and used it to weld up the hot side pipe. I don't mind doing this, I am just having trouble finding another stock intake to cut up online. I haven't been to any boneyards yet, just figured someone might sell the flange itself. Just trying to be lazy if I can. Thanks again guys.
Old May 7, 2011 | 08:37 AM
MagKarl's Avatar
MagKarl
The flange is mostly flat. You could make one by cutting out a ring of sheetmetal and then welding an elbow to it. Just trace out and reproduce the geometry of your stock part so that the seal is evenly loaded and the clamp fits snugly.
Old May 8, 2011 | 11:21 AM
Talyn's Avatar
Talyn
Steve (rideracelivemx7) did the stock modification.
Karl has it, its mostly flat, but with a little bit of a curve to it. Nothing to fancy if you ask me.
Could make one with a piece of sheet metal and a hammer and bean bag if your good at working metal.
Old May 9, 2011 | 10:02 AM
superduty4x4's Avatar
superduty4x4
There has to be somebody who has installed an IC on an OBS and has their stock intake pipe laying around I would think...
0500757Arf
Aug 25, 2016 08:33 PM
gary's1950F1
13
Jun 16, 2016 08:08 PM
that-1redneck
Jan 14, 2012 10:54 AM
King7765
Sep 13, 2011 03:15 PM
robjs111
Feb 16, 2009 06:09 PM
