Sponsored by: Kumho
ABS light comes on
Old May 4, 2011 | 07:38 PM
lspall's Avatar
lspall
ABS light comes on
Symptoms -
1. Turn the key to "on" position all warning lights come on then go out including the ABS light.
2. Start the engine all warning lights come on then go out including the ABS light.
3. Shift into gear no warning lights.
4. Start driving, after about 20 to 30 feet ABS light comes on.
Any ideas ?
Old May 6, 2011 | 01:59 PM
1995droptopz's Avatar
1995droptopz
Probably a wheel speed sensor. Since it doesnt start until you move.
Old May 16, 2011 | 02:34 PM
lspall's Avatar
lspall
SOLVED !!!!!!
Found a place that would do the ABS scan for free, the scan revealed that the passenger front ABS sensor was giving an erratic reading. Since I didn't have the $150 for a new sensor I did a little troubleshooting and found the cause of the problem. Suspecting a broken wire I took the sensor off and cleaned it up, I then put my ohm meter on it (putting each test lead on each prong of the connector) and got a ohm reading of 425 ohms. Not knowing what the range should be, I held the the test leads on the prongs and had the wife bend different sections of the wire. Then SURPRISE !!, found a section that would read anywhere from 0 to 1500 ohms depending on which way the wife bent or rotated that section of wire. So knowing what section was damaged I put the sensor back on the Expedition and positioned that section of wire as straight as possible then went for a test drive. NO LIGHT CAME ON YAAAAAY !!!!
artsamm
Oct 23, 2013 12:19 AM
jimkidd
Sep 25, 2006 07:39 PM
BroncoJoe
1978 - 1996 Big Bronco
Jul 31, 2006 09:11 AM
TigersGrowl
Nov 8, 2003 05:54 PM
