Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
speedometer cable
Old May 4, 2011 | 11:54 AM
jeffz's Avatar
jeffz
speedometer cable
I have a 1980 f-600 ford with a 4 speed manual. Where can I Purchase a new speddometer cable?
Old May 4, 2011 | 02:54 PM
wchain's Avatar
wchain
This forum is for 2009 and Newer F150s.
Old May 4, 2011 | 05:38 PM
LxMan1's Avatar
LxMan1
Moved to correct forum.
Old May 4, 2011 | 06:10 PM
80broncoman's Avatar
80broncoman
so have you figured out which trans you have?
and or do you have a 2 speed rear axle? a 2 speedaxle has a cable that seems to be about a mile long since it will go to the rearend and not the trans.
if you are lucky you might have NP435 trans which might be the same cable as a 1980 2WD f-150 with that trans.
Old May 5, 2011 | 10:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What's wrong with the cable? Is its outer housing kinked, or is there another issue?
The speedo cable is composed of two parts: Outer housing, inner woven steel core. The steel core is supposed to be lubricated every so often, but most peeps are unaware of this.
When the lube dries out, the steel core binds up inside the housing and snaps.
Autoparts stores sell a replacement woven steel core kit. You cut it to length, coat it with a fine film of graphite, install it in the housing.
ligito
Apr 10, 2015 08:00 PM
78 & 87 Super Cab
May 20, 2014 04:27 PM
damarble
1997 - 2003 F150
Jan 23, 2014 03:40 PM
mont974x4
41
Sep 29, 2013 04:24 PM
Brad_9876
Dec 7, 2009 11:37 PM
