Project: 351m to 460BB
Old May 4, 2011 | 11:07 AM
bigforddan's Avatar
bigforddan
Exclamation Project: 351m to 460BB
I have a 460 that i just bought and i plan on making it a performer motor or the mud races.. i am looking to crank out a little over 600horse with out using nos. so i am looking to find double spring valves. i am using the original heads or do i need to upgrade to something different to use performance valves since that is what i am wanting to use. i am using roller rockers. pistons.. they are going to be flat top. also am not boring anything out. but i am also looking for a .500 lift cam or anything bigger, how ever if i decide to go bigger how do i shim everything to make it work? i just need some help looking/finding these parts. please help me asap because i plan on getting this put together around at the end of fall season. i am using a NON-EGR aluminum 4 barrel intake.
Old May 4, 2011 | 11:09 AM
bigforddan's Avatar
bigforddan
I am getting my block, heads, crank, main caps, connecting rods all done wen i get my new pistons in the mail.... p.s. how much would raised top pistons and heads run me if i wanted to do that? cant find anything on them.
Old May 5, 2011 | 04:35 PM
kettle-one's Avatar
kettle-one
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum <--
Join this site and do a lot of reading. What year of heads and block do you have? Plan on aftermarket rods and a ".500 inch" lift cam is not going to get you 600hp, more like 375-425 depending on compression, heads, intake etc. My suggestion is set a budget and expectation along with true intended use of your engine.
Old May 5, 2011 | 08:08 PM
bigforddan's Avatar
bigforddan
77 lincoln mark v block....
Old May 6, 2011 | 07:40 AM
kettle-one's Avatar
kettle-one
It comes down to casting numbers. If your motor came from a 77' then it likely will have a D1VE block with 10.322 deck height and D3VE heads and is internally balanced. Not a bad foundation, but, what are your realistic goals for the engine/vehicle, then comes the budget and what you can afford to do? 600hp is not an overly complicated goal but it takes $$, and a competent builder that knows 460's.
Old May 6, 2011 | 08:41 PM
bigforddan's Avatar
bigforddan
this motor would b my very first big block/high performance motor... i used to have a jeep (blew the motor out of it) then i got my truck now that has a 351m in it so next motor thats going in it is the 460
Old May 6, 2011 | 10:12 PM
kettle-one's Avatar
kettle-one
I feel your pain on the 351m.....pretty gutless. As I said, join the 460 Ford forum and read as much as you can. There is a ton of knowledge and helpful folks their as well as vendors that know the 429/460 engine. There are simple thing you can do to improve the 460 and there a lot of ways to decrease it potential as well. Common upgrades thing are zero deck the block to 10.300" (70 and early blocks excluded) Run a split duration/lift cam, and porting the stock heads for improvement. I can't express enough that this is where you need to go to learn about the 460 and how to build what you want correctly the first time.
SuperCruiser78
Feb 5, 2014 02:25 PM
93f250tn
Feb 23, 2013 01:54 AM
1976fordguy
Dec 18, 2012 07:21 PM
bigforddan
1978 - 1996 Big Bronco
15
May 6, 2011 08:39 PM
30over
May 27, 2010 06:32 AM
