1997 f350
Old May 4, 2011 | 09:20 AM
rungunner's Avatar
rungunner
1997 f350
Hey guys I have a problem that maybe someone can help me with. I have a 1997 Ford f350 XLT with a 7.3 diesiel. When I am driving down the road in cruise control I will go to switch lanes and turn on the turn signal the cruise control will shut off or while in cruise and turn on the cruise the engine speed will change. I took the steering wheel apart and do not see anything that might be shorting out. Any help would be appreciated.
Old May 5, 2011 | 09:44 AM
rungunner's Avatar
rungunner
Help
Someone had to see this problem in their truck?
Old May 5, 2011 | 10:01 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Check your tail lights and the third brake light in the cab for bad bulbs or shorts there. good luck
kupiec20's Avatar
kupiec20
my cruise conyrol would just shut off on the hwy because i had a bad VSS - not sure if this is your problem. good luck.
Old May 5, 2011 | 10:21 AM
rungunner's Avatar
rungunner
vss
what is a vss?
Old May 5, 2011 | 10:31 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
what is a vss?
VSS Vehicle Speed Sensor its in the top of the rear pumpking
Old May 6, 2011 | 08:17 AM
rungunner's Avatar
rungunner
Cruise control / turn signals
My problem has been solved. documented for someone with the same problem.
Inside the steering wheel column the turn signal assembly is bolted to the column by 2 screws with 2 wire plugs going to it. Pull that all apart and you will find 5 or 6 screws holding the turn signal assembly together. Inside that there are copper contacts and depending on which direction your turning or using emergency flashers the contacts move on a plate of different contacts. All of this was very dirty almost like a pennie growing the green mold and causing some kind of short thus shutting the cruise off when I would change lanes with turn signal. I cleaned all the contacts in there and have no more problems with my turn signal / speed control problem. I know about the 3rd brake light and the vss solving other problems but not this time. The only problem is getting the turn signal assembly back together, it was kind of difficult and after 20 - 30 times trying to put it together it finally went back together.
Old May 6, 2011 | 09:19 AM
Deadeye1445's Avatar
Deadeye1445
Im having a problem with my CC too... Sometimes it works and sometimes it doesn't, no idea why it would do this.
Old May 6, 2011 | 11:43 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Glad to see that you resolved your issue, and yes I forgot about the dirty contacts in the MFS, thats a common problem too.
Old May 6, 2011 | 12:02 PM
Deadeye1445
Maybe this is what is wrong with mine, causing intermittent times of working and not working. I'll have to check this out. Thanks!
DieselJerry
Nov 26, 2012 10:23 PM
DorothyB
All Things Towing
17
Aug 17, 2009 08:29 PM
towhaul
Oct 22, 2007 10:31 AM
handy
Electrical Systems/Wiring
Aug 4, 2004 04:14 AM
Valricoboy
Nov 28, 2002 08:55 PM
