Tailgate Latch Broke
Old May 3, 2011 | 08:34 PM
97biostroke's Avatar
97biostroke
As I was moving out of my apartment today I went to open my tailgate and "snap", something inside broke. The passenger side of the handle can come pretty much all the way out, the other side still catches whatever is inside. But basically it broke. Can I replace just that part or do I need a new tailgate? Seems like every time I turn around something has either rusted, busted, or leaked, but I guess thats what I should expect after 240k miles.
Old May 3, 2011 | 08:39 PM
Action4478's Avatar
Action4478
Sounds like you only need a new handle ..
Old May 3, 2011 | 09:08 PM
97biostroke
Well from what I could tell the handle is still fine, looks like it has a hook on each side and I think both sides look fine. But then again I have no idea how that whole assembly works. I'll have to dig into it tomorrow and see if I can find what broke.
Old May 3, 2011 | 09:14 PM
Action4478's Avatar
Action4478
Its either the plastic clip or the handle ...Take it out & look at it ...Then you can tell us how to fix-it ...
Old May 4, 2011 | 05:33 AM
Talyn's Avatar
Talyn
I know how to fix it!!!!
Old May 4, 2011 | 05:35 AM
Talyn's Avatar
Talyn
Its a really simple setup that is replaceable, just go grab a new handle from the junk yard.
take some torx bits and remove the access pannel to get to the back to unbolt the handle.
you can probably use any handle from 87-96 maybe older.
There are 2 plastic clips in there, those have a tendancy to break, but you said the handle is coming out, which means the rivet broke on the handle from the bracket that bolts to the bed.
Just swap in a new handle.
i didn't take pictures when I did this. My truck has the handle out of my f150.
The access pannel is from my f150 as well, cause the truck was missing one.
Old May 4, 2011 | 05:37 AM
Talyn's Avatar
Talyn
The plastic pieces are for the adjustment. It seems weird they are platsic, but while your in there. lube everything up good with fluid film.
and you'll have to play with the adjustments a bit.
I have mine set really touchy. Just a slight pop on the handle and its open, no reefing on it.
They tend to break from being miss-adjusted cause you gotta pull so hard on em.
Badford
Apr 1, 2010 06:47 PM
kadrocker
Apr 16, 2009 09:01 PM
skincer
1983 - 2012 Ranger & B-Series
15
May 14, 2004 04:24 PM
jarrall
Feb 24, 2004 10:55 AM
Robg
1978 - 1996 Big Bronco
Sep 16, 2002 02:47 AM
