Voltage regulator for 6V starter
Old May 3, 2011 | 08:15 AM
52runner's Avatar
52runner
My f1 was converted to 12v but the starter is 6v, i noticed LMC had a regulator,. is that all i need and is this the right part number.....47-0877.
Or does the starter need to be rebuilt to 12V?
Old May 3, 2011 | 08:43 AM
51PanelMan's Avatar
51PanelMan
I believe that you'll need the 12v voltage regulator 47-0878. You may want to contact your local NAPA auto parts store as they should have one in stock. It's a common item that was used on trucks well into the 70s. It'll probably also be cheaper, by the time you add up the shipping cost and time.
You should also get your starter rebuilt to 12v.
Old May 3, 2011 | 08:51 AM
52runner's Avatar
52runner
this is temporary
Will this suffice till i find someone to rebuild my starter? I just wanna keep from damaging my new ring gear.
Old May 3, 2011 | 08:53 AM
fastphil's Avatar
fastphil
I work at a NAPA store. The 6v regulator NAPA part number is VR401. The 12V regulator NAPA part number is VR440 if that helps.
Old May 3, 2011 | 08:56 AM
51PanelMan's Avatar
51PanelMan
I wouldn't do it. I'd spend a hundred bucks or so to get the starter rebuilt to 12v. There's a good place here in San Jose that can rebuild it fast and at a reasonable price. I had my 6V generator rebuilt and he charged me $130. Got it done in less than 24 hrs. The place is called San Jose Diesel Electric. I'm sure that there's an outfit like this in your area.
If you're going to finish the 12v conversion that the PO apparently did (don't you love PO's?), then, in my opinion, do it right the first time. You'll be more money ahead and will encounter less headaches in the future.
Old May 3, 2011 | 09:15 AM
tinman52's Avatar
tinman52
Welder User
I'm confused.....the voltage regulator pictured has nothing to do with your starter. It is part of the charging system.
I am not aware of any way to reduce voltage to the starter.....easily. Having your starter rewound for 12V is the best bet.
Old May 3, 2011 | 12:22 PM
gearhead1952's Avatar
gearhead1952
I agree with tinman that voltage regulator is for the charging circuit not the starting circuit. I have run 6v flathead starters on 12v with no problems makes them sound like a late model starter.
Old May 3, 2011 | 02:34 PM
sparky's Avatar
sparky
Have to agree the voltage regulator doesn't affect the starter it is for the charging circuit. The starter runs directly off the battery, so whatever voltage the battery is rated at is what the starter gets.
Also just to throw this out there.....I converted my 1941 Flathead 4 ford tractor to 12 volts many years ago. Left the starter the original 6 volt and it is still working fine.
Old May 3, 2011 | 03:07 PM
arctic y block's Avatar
arctic y block
I have had a 6V starter on a 272 for over ten years. No problems yet with it getting 12 volts.
Old May 3, 2011 | 03:27 PM
roljr's Avatar
roljr
2 Cents worth
As long as you battery has the amperage needed your starter will only spin faster. No problems. Save your money for when you need a starter.
Bob
Old May 3, 2011 | 04:20 PM
52 5 star's Avatar
52 5 star
My flatheads have 6 volt starters in them also and they just spin faster. The starter does not care if it is 6 volts or 12 volts. The local dc electric shop near me told me it was fine just don't crank it for a long time because it will heat up faster bcause it spins faster. Hope this helps you
warren561
Mar 6, 2019 04:33 PM
F1rb
Aug 24, 2015 10:48 PM
Rusty_S
Jun 12, 2015 06:39 PM
marine1200
1947 and Older Ford Trucks
15
Apr 24, 2015 08:20 AM
tjdad62
Aug 7, 2014 04:56 PM
