CALIPER BAD???
Old May 2, 2011 | 07:40 AM
joeyd61's Avatar
joeyd61
CALIPER BAD???
Okay, so my PMS fever flared up, I havent done any upgrades in a while so i decided to improve my brakes..Keep in mind NO problems with brakes just improvement...Installed Hawks LTS pads and Power Slot rotors,inspected slide pins and cleaned,regreased...Test drive, 35mph stop mildly 8 times, 2 hard stops from 45mph,let cool....Ok that was easy and breaks allready feel better....next day,go to town.. Drivers side front is sticking!!!!..truck pulling hard left, smoking(left front tire)eased her home,appx 10 miles...Havent had a chance to pull tire yet..Caliper bad???did i just ruin a set of Pads?????
Old May 2, 2011 | 07:44 AM
riverrat41's Avatar
riverrat41
Hard to say until you get into it and see a smokin gun maybe.When you get time,pull that left side apart taking time to inspect everything and then let us know what you find.
Old May 2, 2011 | 08:29 AM
99hunter's Avatar
99hunter
I think you could just rough up the pads and through a new caliper on and be goos to go!
Old May 2, 2011 | 08:44 AM
joeyd61's Avatar
joeyd61
[quote=riverrat41;10290763]Hard to say until you get into it and see a smokin gun maybe.When you get time,pull that left side apart taking time to inspect everything and then let us know what you find.[/quot
Yea I know. It will be tomorrow befor I can get to it.I will let you know
Old May 2, 2011 | 08:56 AM
99hunter's Avatar
99hunter
One other thing is that if the inside of the rubber brake line starts to colaps it can act like a one way check valve not letting fluid return.
Old May 2, 2011 | 07:53 PM
joeyd61's Avatar
joeyd61
okay,got home from work and for sh**** and giggles drove the truck to the store....no pulling and no sticking pads...pulled wheel and caliper, all appears good..drove agean, tried breaking hard, nothing but when the truck downshifts i hear a clunkball joints maybe, it got dark and i quit
maybe time for new front end 263000 on factory ????
one more thing....why is my computer underling all of this????
Old May 2, 2011 | 08:14 PM
riverrat41's Avatar
riverrat41
The clunk could be the sway bar bushings or the bushings on the sway bar end links that tie it together.
Did not understand your last statement?
Old May 2, 2011 | 08:52 PM
joeyd61's Avatar
joeyd61
Yep.. understood...I will check it 2morrow.....Thx
helloimjason
Nov 9, 2016 09:31 AM
Johnny Bravo 45
Aug 31, 2016 04:49 PM
mrcrownline
Feb 15, 2013 08:07 PM
neilc88
15
Dec 18, 2012 01:23 AM
SMc
Jul 11, 2004 09:47 PM
