Need quick iTunes help
Old May 1, 2011 | 10:08 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I may have to delete and reinstall iTunes. What will I lose? Apps? Music? How do I get it back if I lose it?
Old May 2, 2011 | 12:08 AM
ford2go's Avatar
ford2go
I'm assuming that you mean uninstall and reinstall.
Music:
Anyway, if you're organized ( not like me), all of the music is in one place.
Somewhere in the setup options, it shows you the folder.
Usually its a folder called itunes music or something like that. But, it will probably go better if you find the exact folder in setup.
I don't think that it will be removed when you uninstall, but you might want to copy it.
When you reinstall, if it's not there, you can go into setup and link it up again.
Playlists
I think that you can export and reimport them. I don't know how iTunes stores them. It probably is a file somewhere, but I'm not sure. Worst case, you'd have to redo them.
Sync to iPod or whatever, I have no idea.
Good Luck, Probably somebody has more specific info. I usually just diddle around until I figure it out -- then I forget exactly how i did it.
hj
Old May 2, 2011 | 10:18 AM
donjamer's Avatar
donjamer
If you can access Itunes the best thing is to do a backup to disc..
It is under the file menu.. Select Library then Backup to disc..
This way it gets all of your apps, music, and licenses..
Then you perform a restore by just inserting the disc and following the instructions..
Old May 2, 2011 | 02:51 PM
bigrigfixer
The Pacifier
I was able to remove and reinstall iTunes without any trouble, even though I did backup the tunes and apps just in case.
The problem is still there. Can't sync iPhone with iTunes. With iTunes uninstalled, the computer knew it was there, and I was able to upload the camera pics to a folder.
When I reinstalled iTunes, and plugged the phone in, it shuts down my laptop, and I get the blue screen of death. Same as before.
I have Windows XP, sp3, iTunes 10.2.2. I guess I may just have to try Applecare again, but I think they are pretty useless.
jvoigt
Mar 22, 2007 11:07 AM
tjc transport
Oct 30, 2005 09:10 PM
warrencowboy05
Jul 26, 2005 03:45 PM
billsco
28
Mar 24, 2004 11:48 AM
