need responce ASAP
Old May 1, 2011 | 02:01 PM
zakk's Avatar
zakk
Exclamation need responce ASAP
so im going to go change my axle seal for the third time today but i remember awhile ago hearing i should empty all the fluid in the axle and put new in when i do the seal because it can be contaminated and ruin the seal again. is this true or not?
Old May 1, 2011 | 02:09 PM
Jayme Duty's Avatar
Jayme Duty
if your fluid is old it would be a good time to change it. i have changed many axle seals and never had a problem of changed the fluid
Old May 1, 2011 | 02:10 PM
zakk's Avatar
zakk
ok sweet thank you
Old May 1, 2011 | 02:18 PM
Jayme Duty's Avatar
Jayme Duty
just make sure that you clean the surface where the seal sits very well. Also i know it sounds dumb but make sure you put that seal in the right way.
jonnydz
May 15, 2013 04:21 PM
ajsanteiro
Nov 22, 2012 12:09 PM
little_mule
Nov 4, 2009 07:33 PM
Neal 97 250
43
Sep 4, 2009 11:41 AM
oldsw-31
Nov 21, 2006 08:18 AM
