Power window motor replacement
Old Mar 21, 2003 | 04:18 PM
cazbat's Avatar
cazbat
Question Power window motor replacement
1993 Explorer Sport 2D I am trying to replace the power window motor but can not get to the last bolt/screw. I have taken out two bolts and poped out the three rivets. There is one more bolt that I can not get to. I have a Haynes manual (P.O.S.) and of course it does not have anything about it.
The motor will not budge. Any ideas???
Old Mar 21, 2003 | 07:16 PM
rbraughn's Avatar
rbraughn
If it is anything like my old Marquis I had, you have to drill a hole large enough to get a nutdriver or ratchet extension through.
The factory actually went so far as to put a "ding" mark with a punch to show you exactly where to drill.....Profanity Removed!!..... if they could do that, why didn't they just go ahead and drill the damn hole ??!!
Old Mar 21, 2003 | 07:59 PM
cazbat's Avatar
cazbat
Lightbulb Power window motor replacement
You know I saw that ding and was thinking this might be the way but I had the other side replaced a few months ago by a shop and they didn't drill to replace it.
I was thinking there was probably some sort of special tool but I can't see the harm in putting a hole there
Old Mar 24, 2003 | 01:22 PM
iloveelectricity's Avatar
iloveelectricity
Smile Power window motor replacement
Yep, i had to do the same on mine. Just drill out where that dimple is and you should be ok. P.S. those things suck to change.
Old Jun 8, 2003 | 09:57 PM
txlaker's Avatar
txlaker
Worked on my new 93 explorer this weekend. Need help with removing power window regulator. Drilled holes and can remove the motor which works fine. I suspect the plastic gear is stripped. How do I remove it? Drill out rivits? replace with what? A local salvage yard sells the gear for $25 new !!! I wanted to see how is it removed then replaced before I buy it. Any help?
Old Jun 9, 2003 | 09:05 PM
rbraughn's Avatar
rbraughn
I just bought a re-built one at the local auto parts place. The re-build kit wasn't much cheaper than getting the whole motor, but my motor was bad, not the gear.
Lariat 4x4
Jun 29, 2017 11:16 AM
Glenn54
Nov 21, 2016 05:08 PM
wrhatt
1978 - 1996 Big Bronco
Jun 28, 2016 02:15 PM
dkocian
1997 - 2003 F150
Oct 5, 2011 12:07 AM
ktmkid
Aerostar
Aug 13, 2004 04:58 PM
