Tail/brake light wire harness?
Old Apr 30, 2011 | 09:46 PM
4x4x7879's Avatar
4x4x7879
I want to replace the wiring harness from the plug that is located under the driver side of the tailgate and runs to each tail/brake light lens. Does anybody make this section? Do i have to make my own? The one on my truck is not to bad but is in need of some work so i would rather replace it or make a new one instead of bandaid what i got. Thanks for any help.
Old May 1, 2011 | 12:19 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The part you need is:
Wiring Assy., Rear lamp connector
D4TZ-13A409-A (marked D4TB 13A409-AA)
Fits 74-up F100-350 From s/n T80,001
My parts locating service is down right now, once it's back up I'll see if I can locate any.
Old May 1, 2011 | 12:54 AM
4x4x7879's Avatar
4x4x7879
I will wait for your response. Thank you
Old May 1, 2011 | 01:44 AM
mikeo0o0o0's Avatar
mikeo0o0o0
My locator service is back up, it shows that part is unavailable. Sorry.
There may be some out there, this service doesn't cover ALL the dealers and parts suppliers.
Old May 1, 2011 | 03:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I found one on the Ford Dealer Parts Locator System.
D4TZ-13A409-A .. Wiring Assy-Rear Lamp Connector / Obsolete
Fits Stylesides: 1974 F100/350 from serial number T80,001 / 1975/79 F100/350.
CROSSET FORD L/M in Crosset AR has ONE = 870-364-2162.
No other FoMoCo Dealer, no obsolete parts vendor has any.
Old May 1, 2011 | 09:18 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks for the update Bill, I appreciate it.
Old May 1, 2011 | 10:48 AM
4x4x7879's Avatar
4x4x7879
Thanks you for all the help from both of you. I will call and see how much they want for it and decide if i make my own from there. Thanks again.
Old May 1, 2011 | 01:17 PM
thatsrealnice's Avatar
thatsrealnice
taillight wiring
here's a company that makes wiring harnesses. 49.99. probably about the same amount you'd pay if you bought all the wiring and looms etc. comes with the sockets too. if the rubber part of your connector is in good shape, you can splice the new wiring to the rubber connector so you can still plug/unplug easily.
MrTailLight.com Online Store
Old May 1, 2011 | 11:35 PM
4x4x7879's Avatar
4x4x7879
That is a nice wiring harness. I will definitely look into it. Thanks
Old May 2, 2011 | 12:25 AM
VocaTexas's Avatar
VocaTexas
Slightly off topic, but has anybody bought their grille parts? They're a lot cheaper than LMC etc.
Old May 2, 2011 | 08:31 AM
78 PEB's Avatar
78 PEB
Good link.......................I've got that one saved in my favorites for future reference.................Thanks
Old May 2, 2011 | 10:22 AM
78SB300's Avatar
78SB300
I was noticing that as well. Might be interested in purchasing the grille and headlight kit.
Old Sep 23, 2011 | 10:38 PM
PlumLoco's Avatar
PlumLoco
Rear Wiring Harness plus adapter 1979 F100
I like the Mr Taillight.com rear tail light wiring but I really need the part just in front of that also that it plugs into. My truck is definately a work in progress and when I saw the wiring underneath in the rear I actually felt better about what was under the hood and that is saying something. If anyone knows what that junction plug is called and where I can get one of those I would appreaciate the heads up.
Thanks
JC
Old Sep 24, 2011 | 02:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks
JC
More info is needed to get the right p/n but taking a guess, '79 F100 2WD reg. cab, 133" WB.
Wiring assy, rear lamp
D8TZ-14405-D
I couldn't locate any dealers or obsolete suppliers that had one, sorry.
Old Sep 25, 2011 | 10:33 AM
supercabfreak's Avatar
supercabfreak
my uncle is doing a 81 chevy k-30 restomob and hes useing all new weather pack conectors .......since hes bought the tool chances are i will to when i cross that road
