AFE big boost question
Old Apr 30, 2011 | 05:47 PM
Pitcrw6's Avatar
Pitcrw6
I finally got some time to install my afe big boost filter and I have a few questions for u experts. First off I only removed the top half of the stock airbox and left the bottom connected for now or maybe for good. Question # 1 what do I do with the filter minder and the other small plug that was connected to the airbox? Question # 2 I used one of the 4 inch round pipe sleeves for clamping the intake tube and the filter but the filter rubs against the side of the fender and nothing keeps the filter from moving around. I had a sheet of teflon that I cut and put on the edge of the fender so it wouldnt rub a hole in the filter cover. I also screwed 2 pieces of teflon where the middle of the airbox screws are. I had to loosen the opposite side of the intake tube and rotate it down some so the filter wouldn't hit the hood when closed. Did I install this right?
I did take it for a ride and I love hearing the whistling sound from the turbo. I took a pic with my phone and will try to attach it. No luck trying to attach it. with my phone, guess im just doing something wrong, ill have to try with the computer.
Old Apr 30, 2011 | 06:01 PM
woodnthings's Avatar
woodnthings
The filter minder can be left unplugged if you want. The air intake temperature sensor needs to be plugged in if you want the warm up and EBPV to operate. They can both be secured out of the way and stowed if you choose.
Old Apr 30, 2011 | 06:12 PM
Pitcrw6's Avatar
Pitcrw6
Ok, so i think i got the pics loaded. You can see the piece of teflon on the side and in the middle where the 2 screws are.
Dr. Johnson
32
Mar 6, 2024 06:44 PM
Encho
1978 - 1996 Big Bronco
42
Jun 5, 2021 04:42 PM
cqualls43
16
Jan 26, 2017 01:15 AM
Ford79
41
Jan 3, 2009 04:37 PM
BigTomMiller
Aerostar
Oct 12, 2003 01:12 AM
