B&M shifter problem
Old Apr 30, 2011 | 05:07 PM
tchopper1969's Avatar
tchopper1969
B&M shifter problem
I have installed a C4 transmission in my 66 slick that originally had a C6. The shifter was working perfectly fine with the other transmission, but when I go to install it on the C4, I notice that the throw on the cable doesn't match with the linkage on the transmission. Is there a way to change the throw on the cable or do I need to get another cable?
Thanks for any help/advice
Old Apr 30, 2011 | 05:13 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Did you save the box it came in?
Theres a bunch of adapters in there.
Old Apr 30, 2011 | 05:18 PM
tchopper1969
no i dont, was already installed on the truck when i bought it
Old Apr 30, 2011 | 06:02 PM
Ziegelsteinfaust
You could probily contact B+M to see if what you need will be in the box or I am sure they have it on a shelf.
Old Apr 30, 2011 | 06:04 PM
tchopper1969
awesome, thanks for the help
Old May 1, 2011 | 08:18 PM
meckman33's Avatar
meckman33
i think the c4 and c6 use different mounts and shift levers
Old May 5, 2011 | 11:47 AM
tchopper1969
thanks for everyone's help. got the correct parts on there now but i am still having a shifting issue problem. it surges between 2nd and 3rd gear, thinking some debris may be caught in the valve body somewhere so i am manually shifting for now til it clears up. sure don't want to have to replace clutches
Old May 6, 2011 | 06:48 AM
meckman33's Avatar
meckman33
surges
hello check vacume line to modulator valve adjustment on kickdown lever from carb. did it do this before shifter work was performed
schoo
May 31, 2016 09:10 AM
Ceaumar
May 11, 2016 04:52 PM
svolpone
Jul 11, 2014 07:41 AM
dougamorrissey
1997 - 2003 F150
Feb 1, 2012 08:13 PM
first today
Feb 14, 2010 04:45 PM
