Transmission slippage?
Old Apr 30, 2011 | 10:34 AM
Mitch-FF's Avatar
Mitch-FF
Recently purchased a '99 Expedition 5.4l
2 problems with it, not sure if they're directly related or not:
- Shifter is sloppy going into the gears. Sometimes I have to "fish" for the sweet spot to get it into gear, mostly reverse. Also doesn't completely go into Park unless I knock it in a couple of times. -- I suspect the transmission cable is the culprit here, either slack or the end slipping at the steering column end.
- Once I get it into gear, it kind of eases in. For instance, when I get it into reverse I have to rev the engine a bit and reverse slowly engages.
Could the second problem be caused by the sloppy cable not getting the linkage into the proper position, or is it independent of the cable and indicative of an impending rebuild?
Thanks,
Old Apr 30, 2011 | 12:36 PM
Moto Mel's Avatar
Moto Mel
There are some torx bolts on the shifter column that need to be tightened that are under the dash. There have been several threads regarding this so do a search. Some have pics that will help a ton. It's a 15 minute job according to those that have done it. Once it is tightend up all those problems may disappear.
Old Apr 30, 2011 | 01:46 PM
alloro's Avatar
alloro
Pay attention to my posts #2 and #10.
https://www.ford-trucks.com/forums/8...n-shifter.html
Old May 1, 2011 | 02:53 PM
Mitch-FF's Avatar
Mitch-FF
Thank you for the replies. I don't have a Torx 25, but was able to check the triangle shaped bracket mentioned. The screws appear to be tight and there is no play at all between the bracket and the shifter, or the cable end.
Old May 1, 2011 | 09:07 PM
alloro's Avatar
alloro
In that case remove the top cover off the steering column. Under it you will find the shifter shaft and two bushing that it runs through. See if these bushings are missing or worn out.
Old May 1, 2011 | 11:13 PM
Mitch-FF's Avatar
Mitch-FF
I had the top cover off previously and things seemed fine, but I'll pull it again tomorrow and check the bushings more closely.
Thanks,
Mitch
Old May 2, 2011 | 12:52 PM
Mitch-FF's Avatar
Mitch-FF
Both bushings are present, at base of shifter handle and at the cable bracket. Both bushings are solid, no play or signs of wear.
Thanks,
Mitch
Monster-4
Jan 21, 2017 02:59 PM
Copedawg
Sep 30, 2016 02:04 PM
Rob_82
Jun 2, 2015 07:25 PM
Keepitrunnin
Feb 9, 2015 08:02 PM
The_Builder
Dec 17, 2013 02:54 PM
