Help with #8
Old Apr 29, 2011 | 09:41 PM
grizzweideman's Avatar
grizzweideman
Help with #8
Hello I have replaced #8 injector 3 different times then on the 4th time i replaced the valve cover gasket and harness and it is still running bad and the mechanic did a buzz test on it before and after and the tester said that #8 is not getting any power could the truck computer be the problem. I can`t figure it out so any help would be grate thanks.
Old Apr 29, 2011 | 09:42 PM
grizzweideman
Oops it`s a 1999 super duty 250 7.3
Old Apr 29, 2011 | 10:00 PM
oldbird1965's Avatar
oldbird1965
Interesting post though.
Old Apr 29, 2011 | 10:18 PM
BuckHammer's Avatar
BuckHammer
If I were you, I would go ahead and post this same thing on this board: 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
I'm sure guys here will be more than able to help you, but your truck is a Super Duty, so you might as well take advantage of the increased traffic they get on the Super Duty board.
grizzweideman
Apr 30, 2011 04:13 PM
trcno
13
Jun 23, 2010 02:36 PM
JakeTheSnake
Feb 7, 2006 07:42 PM
alwaysmessedup
Jun 23, 2003 11:36 PM
trentveronica
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 14, 2003 04:09 AM
