Stumped
Old Apr 29, 2011 | 07:39 PM
cheezit's Avatar
cheezit
sync issues are caused by cam/crank sensor or there related parts.. ie wire harness, tone rings etc.
I dont guess you have a 2 channel lab scope handy?
like I said before check ohms then swich the fluke to freqs and retest. that will be as close as you can get
Old Apr 29, 2011 | 07:44 PM
Fordnatic68's Avatar
Fordnatic68
No no lab scope. K ill go out and do ohm & freq test, have beer now so im back in my happy place haha. Not sure if this helps but no rpms on tach only when I have edge plugged in and set for rpm monitoring.
Old Apr 29, 2011 | 09:14 PM
Maxium4x4's Avatar
Maxium4x4
Originally Posted by cheezit
lmfao welcome to a little taste of my world.
See I told you someone would be along tonight and Moe, I wouldn't handle your world very well, I hate electrical issues. Come to think of it our electricians at work do not handle them very well at times.....
Old Apr 29, 2011 | 09:16 PM
cheezit's Avatar
cheezit
dont feel bad I like to stick to 12v dc myself. the 110 230 and 440v scare me.
Old Apr 30, 2011 | 09:42 AM
Me Repair/Gotta Eat's Avatar
Me Repair/Gotta Eat
I have the same issue and with my scan tool I can see the sync message "yes" any other thoughts?
Old Apr 30, 2011 | 09:44 AM
Me Repair/Gotta Eat
sensors ohm at 347 ohms and I checked at the PCM connector so I assume the wiring is ok.
Old Apr 30, 2011 | 09:45 AM
Me Repair/Gotta Eat
do you think the PCM is bad?
Old Apr 30, 2011 | 10:49 AM
Fordnatic68
hang in there someone will jump on at some point. What issues are you havin?
Im headin back out to work on the ole girl now.
Old Apr 30, 2011 | 11:18 AM
cheezit's Avatar
cheezit
you need to look at both sync and ficm syn. also make sure you geta freq reading while cranking. also check both crank and cam.
also please keep in mind that different year trucks have different issues. knowing what we are dealing with may help a little bit.
Old Apr 30, 2011 | 02:58 PM
Fordnatic68
I dunno if this helps but when it first pulled this no start condition i pulled a 2285 and a 2623 code. I changed icp and ipr and no change. Does that sound familiar in any way? Ive gone over every inch of harness and unless im blind i cant see any short anywhere. Im not totally sure how to do ficm sync without modis, I just finished checking wires from pcm to ficm and as far as i can get to cam and crank sensors. Brain is starting to heat up and patience is wearing thin with this mess. This is my daily driver and i need to get back to work.
Old Apr 30, 2011 | 03:17 PM
cheezit's Avatar
cheezit
when you replaced the icp did you replace the connector
Old Apr 30, 2011 | 03:24 PM
Fordnatic68
It had been done previously.
Old Apr 30, 2011 | 03:28 PM
  #28
Fordnatic68
would a short between icp wires cause a no start?
Old Apr 30, 2011 | 03:29 PM
  #29
cheezit's Avatar
cheezit
yup thats what I was gettn at.
short vref to sig return...
also miswired will do it
Old Apr 30, 2011 | 03:32 PM
  #30
Fordnatic68
ill go check it specifically right now, but its been done for awhile. back in a bit
