Good Tune/Programmer?
A lot of folks on here are happy with their DP tuners. Jodi at DP can build you custom tunes (specific to your year, model, version, personal modifications, etc etc) as opposed to just giving you a 'general' tune that they hope works with your truck, e-mail you new programs that you can upload via USB, offers 'live tuning' at tech days and it gives you the ability to switch between programs on the fly.
There are a ton of threads on this topic though - so I highly recommend using the [Search] button at the top of the screen, or checking out their web site.
There are a few others as well, which I'm sure someone will be happy to mention momentarily.
Also - check the sticky threads for 'common mods'.
This question comes up a lot... it's right up there with "What size tires will fit on my truck?" and "what should I mod first?"
Edit: And to answer your question - a tuner is typically a chip that works in conjunction with your oem ECU, where as a programmer makes adjustments to the ECU itself. With a tuner or chip, all you have to do to return to stock is unplug it. This is also handy for troubleshooting if you're ever worried that your programming is causing a problem.
I'd love to take a look, compare and pick your brain! Shoot me a PM and we will exchange contact info.
swampfire79
01-19-2012 05:23 AM
