steering gearbox
Old Apr 28, 2011 | 04:29 PM
low 66's Avatar
low 66
steering gearbox
I have a 66 f100 it needs a new power steering gearbox but I think the one on it isn't original I think it was added or has been replaced how can I tell what the one on it is so I can order the correct one
Old Apr 28, 2011 | 05:28 PM
65jim's Avatar
65jim
Here's what a 66 came with. A bendix box with a 4 bolt cover on top. If you have a 2 bolt, it is a saginaw/ford box. Not original,but will fit with a newer column and modifcations..
Old Apr 28, 2011 | 08:28 PM
low 66's Avatar
low 66
Yep mine is a ford two bolt style it is already in the truck so I think im going to get one for a 68 f100 and see if it matches
Old Apr 28, 2011 | 10:46 PM
jhooch's Avatar
jhooch
Wait! 68's used the Bendix style box. Ford started using the Ford style box in mid '69. If you get one for a 68 it will most likely be wrong. I'd go early 70's to be sure.
Old Apr 29, 2011 | 02:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bendix P/S: 1966/68 F100/250 2WD / 1969 F100/250 2WD before serial number D96,001.
1969 F100/250 2WD's & F350's from serial number D96,001 was when Ford P/S was first introduced.
No P/S was available in F350's before D96,001. Both these P/S systems were optional, so not all these trucks will have P/S.
Old Apr 29, 2011 | 06:55 AM
low 66's Avatar
low 66
When I ordered it their was an option for bendix or ford/saginaw in 1968 so I went with ford hope it works if not I got it from my local auto store so I can exchange it for a newer year
mooch94122
21
Aug 19, 2012 04:47 PM
mapolo
Nov 13, 2009 09:50 AM
saauvenshine
Apr 13, 2008 10:43 PM
1969FordF250
Mar 26, 2007 02:27 PM
plowtruck
Feb 14, 2004 07:28 PM
