steering gearbox
Old Apr 13, 2008 | 01:38 PM
saauvenshine's Avatar
saauvenshine
Question steering gearbox
I have a n.o.s steering gearbox and shaft I'm putting on my 54 ford. My question is can I dissconnect the old gearbox and pull out bottom and slide new one in tube and bolt on without pulling whole thing through cab. I was just seeing if anyone has done it this way and if there would be anything obstructing it from coming out bottom. Thanks
Old Apr 13, 2008 | 02:59 PM
Kurt G.'s Avatar
Kurt G.
I'm not sure. But let me tell you a story of a kid with a 55 ford F100 (me) and I pulled out the shaft and cut 3 inches out of it and the welded it together. This was back in 1977 and I don't remember what I pulled but I did not remove box. Also after cutting down shaft I ground in a 45 degree angle on both peices. Set on floor of shop and tacked it , rolled it, repeat. After 4 times weled it solid. My point is I got shaft out without removing box.I did have to remove inside tube. I'm sure that didn't answer your question though. Kurt G. Y-blocks rule.
Old Apr 13, 2008 | 10:43 PM
Kurt G.'s Avatar
Kurt G.
Bump to top... Kurt G. Y-blocks rule.
Low 150
Jul 11, 2015 12:24 PM
zwaechte
May 25, 2015 07:50 PM
mchaffee
Mar 21, 2010 01:01 PM
51truck
Dec 30, 2002 05:17 PM
spectrum
Jan 16, 2001 03:19 AM
