Heater
Old Mar 21, 2003 | 09:39 AM
dpbrowne's Avatar
dpbrowne
Heater
1987 F150 with a 351w. Heater stays on all the time. All the other controls work. I cannot shut off the heat Where are the likely places to look first. Summer will be here before I know it. Thank you
Old Mar 21, 2003 | 07:38 PM
steve83's Avatar
steve83
Heater
Do you mean the fan motor runs whenever the key is on? Or do you mean there's always warm/hot air drifting out of the registers?
Old Mar 22, 2003 | 02:42 AM
dpbrowne's Avatar
dpbrowne
Heater
There is always hot air coming through the vents. Tha fan works fine when switched on.
Old Mar 22, 2003 | 10:18 AM
steve83's Avatar
steve83
Heater
Remove the glove box and follow the cable that wiggles when you slide the temp control to the green spring clip. If the slide moves too easily, but the temp never changes, the cable housing probably popped out.
If the slide doesn't move all the way, the film hinge on the temp door may have split and you'll have to remove the evaporator core to get to the door.
Rasputin53
May 29, 2014 12:04 PM
RA31925
Mar 5, 2013 08:28 PM
WALJON
19
Dec 12, 2009 09:10 PM
Wylbur
Jun 12, 2009 07:31 PM
retro48/52
Nov 16, 2008 06:39 AM
