Driveshaft angle problem.
Old Apr 28, 2011 | 11:10 AM
Ford4X4ingboy's Avatar
Ford4X4ingboy
Question Driveshaft angle problem.
Hey, My buddy has a 1979 Ford F250 with 8" lift on 38" tires. His rear Driveshaft recently dropped out. We're not 100% sure why yet but i thought maybe it has something to do with the angle being too extreme and stressing out a U-Joint. What do you guys think?
And if that is the case how should we go about fixing it and making the angle less extreme?
Old Apr 28, 2011 | 11:13 AM
mark a.'s Avatar
mark a.
CV joint...
Old Apr 28, 2011 | 12:46 PM
Ford4X4ingboy
Originally Posted by mark a.
CV joint...
Where can I find a CV Joint? Unless i'm just blind, I havent been able to find any CV joints anywhere? :/
Old Apr 28, 2011 | 02:14 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Degreed shims under springs to help with the angle. With that much lift I imagine you need to lengthen driveshaft.
Old Apr 28, 2011 | 04:11 PM
Ford4X4ingboy
How do you lengthen your driveshaft? Buy a new one? haha
Old Apr 28, 2011 | 04:19 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
No, most machine shops can do it for you.
Old Apr 28, 2011 | 08:12 PM
evam350's Avatar
evam350
I hear its a lot cheaper to shorten them then it is to lengthen them so if you could find a longer one cheap at the junkyard and then have it shortened it could save you some $$ because at the ez pull here they are only $10
Old Apr 28, 2011 | 09:33 PM
Khyren's Avatar
Khyren
There used to be a place that sold 1 ton CV axles for trucks like severely lifted broncos. I think they could do 28* of angle without issue. ((in googling; High Angle Drivline-Call Jesse at 530-877-2875 ))
hope that this helps you.
Old Apr 28, 2011 | 10:49 PM
73 ford guy's Avatar
73 ford guy
find a front cv shaft from a 2000 ish ford superduty and use it. The slip yokes are 1410 ujoints and 1350 cv joints. Make sure its a 1350 joint cv as they are much stronger. Alot of people dont do driveshafts properly. Dont just rotate a regular driveshaft up it will probably just throw the joints out of phase. Dont know what I'm talking about read this when I post half ways down the page
https://www.ford-trucks.com/forums/9...e-shaft-2.html
want more read this article I learnt all my knowledge from then you'll know what works and what doesnt!
Pirate4x4.Com - Extreme Four Wheel Drive
Old Apr 29, 2011 | 06:15 PM
Ford4X4ingboy
How much would this cost roughly? And compared to getting the front CV shaft off a superduty?
Old Apr 29, 2011 | 09:22 PM
73 ford guy
My new cv alone cost me about $300. A superduty shaft can be bought for maybe $50-150. I just realized his truck is a 79 so it will have a married t case and have a longer rear shaft. The angle shouldn't be all that bad. Put an angle finder on the shaft and tell me what it runs at. Use a finder with the needle that floats vertical on a protractor that's the first step to us helping you and maybe take a pic. Its hard to go off nothing
O and the superduty shaft might be too short because your rear driveshaft is pretty long. The cv can be cut out and put in a longer shaft and 1410 yoke used as well.
Your probably looking at 3-400$ at a driveshaft shop and parts
Old Apr 29, 2011 | 11:31 PM
Ford4X4ingboy
I'll try to get a picture tomorrow. Hes no mechanic but i had him measure it and he says its 47 & 1/4 in long.
Old Apr 29, 2011 | 11:33 PM
Ford4X4ingboy
I just noticed that some 79s (Like my friends) have round headlights while others have square? When did they change the lights? Mid year?
Old Apr 30, 2011 | 12:06 AM
73 ford guy
Get the angle on driveshaft that's the important part.
I'm pretty sure 78 was round lights square bezel then 79 was square lights fir sure.
Driveshaft doesn't seem all that long. Superduty one may work. Check to see if the tcase is divorced or married, divorced being more centered has a short 1 1/2 foot driveshaft it if you didn't know the difference.
Old Apr 30, 2011 | 08:45 AM
Ford4X4ingboy
Well he says his is a 79 and it has round lights. And then i googled 1979 ford f250 and like two of those ones had round headlights???
