Finally doing a D60 front conversion
Old Apr 28, 2011 | 07:38 AM
PA74F250's Avatar
PA74F250
After much debating and searching I purchased a complete D60 from a '79 F350. Along with that I got everything from the steering setup out of the truck too and also a new set of 4.10 gears since it has 3.50's in it now. I've got some work ahead but its time to say by bye to the leaky power assist closed knuckle low pinion 44.
Old Apr 28, 2011 | 11:29 AM
mark a.'s Avatar
mark a.
You will have a much better drive shaft angle as well.
Old Apr 28, 2011 | 02:38 PM
PA74F250's Avatar
PA74F250
Yea man I'm looking forward to it. So far I dont see any negatives to the swap.
Old Apr 28, 2011 | 02:57 PM
ChaseTruck754's Avatar
ChaseTruck754
Cost is usually the only one...
Old Apr 28, 2011 | 03:12 PM
PA74F250's Avatar
PA74F250
I agree that's why it wasn't done sooner. I feel I made out good on the stuff I got so I'm kinda excited.
Old Apr 28, 2011 | 06:56 PM
Scolesy8's Avatar
Scolesy8
was the 79 F350 u got this axle from junk?
Old Apr 28, 2011 | 07:08 PM
PA74F250's Avatar
PA74F250
Yea it was pretty rusty. It had some good parts that were salvaged but the rest was scrapped.
Old Apr 28, 2011 | 07:34 PM
Scolesy8's Avatar
Scolesy8
ah ok, i was gonna say... if you found a 4x4 '79 F350 (a true one) i'd be tryin to revive that thing
Old Apr 28, 2011 | 07:41 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by PA74F250
I've got some work ahead but its time to say by bye to the closed knuckle low pinion 44.
No more 3-point turns either, much better turning radius with the open knuckle 60.
Old Apr 28, 2011 | 07:44 PM
PA74F250's Avatar
PA74F250
It was a true 79 F350 but unfortunately it was a plow truck for a business. It wasn't bad to look at till you looked under it. Surprisingly the axle wasn't really rusty.
Old Apr 28, 2011 | 07:48 PM
PA74F250's Avatar
PA74F250
This is true. With the 40's on even lifted some now I still have the problem with rubbing the steering arm turning right. Thats where the 3 point turns come in.
Old Apr 28, 2011 | 08:09 PM
montana_highboy
The 78/79 D60 is 1.5" wider than the earlier 73-75 closed knuckle 44's, so you'll get 3/4" more clearance between tire and frame.
Old Apr 28, 2011 | 08:30 PM
PA74F250's Avatar
PA74F250
Really now that I didn't know but I like. Only downfall to that is my tires are 14" wide on a centerline offset rim and already hang out about 3".
Old Apr 28, 2011 | 09:32 PM
Deluxetruck's Avatar
Deluxetruck
I found that out the hard way when my truck would no longer squeeze between the fenders on my trailer. Good excuse to buy a deck-over gooseneck though.
-Jared
Old Apr 28, 2011 | 11:00 PM
73 ford guy's Avatar
73 ford guy
DONT waste your time with the steering arm on the driver side like the stock setup. Do crossover steering right away it will be your best upgrade you can do to start. Any other questions you can just ask. I run a 79 d60 with 5;13's,crossover steering with hydro assist, ubolt flip, high steer, detroit locker, 35 spline chromoly axles with warn hubs. These axles are very expensive to build but in the long run it is very strong. I got about $4000-5000 into mine with all the above
