Where in the heck can I find the flexable a/c ducting for our trucks?
Old 04-26-2011, 06:07 PM
Highboy74's Avatar
Highboy74
Highboy74 is offline
I've looked in Dennis Carpenter, LMC, and NPD. These suppliers do not have any of the ducting thats is the flexable stuff that is under the dash of our trucks. Where the heck can I find this stuff?
Old 04-26-2011, 06:55 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Check with NPD again but use early Mustangs for your application. The ducting should be the same ID... maybe the length too.
Old 04-26-2011, 06:59 PM
fordtrucknut77's Avatar
fordtrucknut77
fordtrucknut77 is offline
i have heard of people using dryer duct...i do say HEARD i have never actually tried it.
Old 04-26-2011, 08:25 PM
HIO Silver's Avatar
HIO Silver
Dryer ducting is 4-inch... if ya can't find or locate OEM or repro ducting, auto parts stores sell flexible aluminum ducting intended for heat risers (btwn the exhaust manifold heat shields to the air cleaner intake)...Bring your ratty ducts with you for comparison. Lastly, I think you'll still have to figure out how to secure them so they stay in place... zip ties maybe.
Old 04-26-2011, 09:34 PM
HIO Silver's Avatar
HIO Silver
Following up......NPD and LMC both carry ducting with 2.5-inch ID for 56-72 rigs...measure your ID and maybe it's the same... NPD sells it in a 6-foot length. PNs are 18556-1A and F-18556-3A.
Old 04-26-2011, 09:54 PM
union bubba's Avatar
union bubba
union bubba is offline
I would worry that the cheap Flex aluminum ducting would get dented up and not let all air flow thru them
Old 04-26-2011, 10:28 PM
Greyman's Avatar
Greyman
Greyman is offline
I have the OEM hard plastic duct that runs behind the instrument cluster. I check the junk yards, and get when I find it. pm me if you want pics or are interested.
Old 04-26-2011, 10:59 PM
HIO Silver's Avatar
HIO Silver
Go ahead and worry cuz it's your call to do or not... I'm only providing resources or alternatives that may not be readily apparent if there is no junkyard within a reasonable distance. "Reasonable" as in a distance that's also for you to decide.
Old 04-26-2011, 11:30 PM
Highboy74's Avatar
Highboy74
I saw all the ones your talking about. I have the problem of it being ripped at the register where it clamps. It is square at the register and the clamp is built into the ducting. Any ideas is to how to secure the round ducting to the square register?
Old 04-27-2011, 01:32 AM
starwriter's Avatar
starwriter
starwriter is offline
I think NASA solved the square peg round hold problem back in the 70's... J/K. For mine I used fiberglass and a PVC fitting to make an adapter that I attached to the duct. It isn't beautiful but it works and it's not like it gets seen anyways.
48f68
05-18-2016 11:00 AM
mikepo
15
08-27-2015 10:56 PM
meborder
07-03-2015 06:24 PM
lumberjack_964
02-23-2015 06:13 PM
MikePacey
30
09-05-2011 04:52 PM
Quick Reply: Where in the heck can I find the flexable a/c ducting for our trucks?
