Blowing tires!
Old Apr 30, 2011 | 04:30 AM
  #31
CPaulsen's Avatar
CPaulsen
I would just go with LT tires....load range E should be good enough. A lot of new 5vers are equipped with LT's from the factory.
Old Apr 30, 2011 | 06:48 AM
  #32
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Originally Posted by oldbird1965
Denny, I just noticed, where in Ne are you. I'm in Lexington, Ne at the present time. Maybe the shop you used is in Ne? I would have to go back and read this thread again, maybe you never did because you have the MorRyde.
We use Nebraska for a home base now but will be leaving Florida on Sunday and heading back that way for a few months. I had my axles aligned in Kearney Ne at Bear Frame & Alignment (308) 234-1220 (I'm 90% sure this is the name). I have MorRyde RE (rubber equalizer) so I still have axles and springs just like you. They did ours about 6 years and 60K miles ago and I have not had a wear problem sense just JunkYear 614 G problems. This place also does a lot of trailer repair so they should be able to find and repair and suspension problems you may have, back when I had our done it was only $80 a axle.
Get your axles aligned and install a set of 17.5 wheels and tires and your tire problems will be over, we still use one of our old 614G tires for a spare because the size is very close to the 17.5 tires.
Denny
Old Apr 30, 2011 | 07:52 AM
  #33
fast_st's Avatar
fast_st
I'm not sure if this applies, but what I usually carry is a non-contact IR temperature meter, available at HFT, and Home Depot type places, from 4 feet away it reads a 10 inch spot for temperature. When traveling and stopping for fuel or after the 20 mile break for a walk around check, I can scan all the vehicle tires and hub temperatures, any tire that's overloaded or carries say in excess of a few hundred pounds of its neighbor will be hotter by a few degrees. Any tire that's low on pressure will also show up as a hot tire. I would think that the failures here are thermal failures from axle mis alignment or a slow leak causing pressure drop and overheating. On a X country trip with 20k loaded on load range D tires, saw the temps runnin 135 F so opted to add 10 lbs of air to each tire, finally the temps settled down to around 100F running on a cool day. Knowing the tire temps and hub temps even in approximation is a handy tool.
Old Apr 30, 2011 | 08:11 AM
  #34
oldbird1965's Avatar
oldbird1965
Small world, I've been to that place in Kearney. I lived there for seventeen years before selling our house two years ago and buying one in AZ. We are still trying to sell our cabin at Johnson Lake so we are here. Monday I'll call Bear Frame, Thanks
I'll have to get one of those temp readers, sounds good. I'll say this, none of these tires have ever had a slow leak. They are good in that aspect.
Old Apr 30, 2011 | 03:00 PM
  #35
rvpuller's Avatar
rvpuller
Our old house now homebase is in Republican City gateway to the Harlan County Lake.
Denny
Old Apr 30, 2011 | 08:54 PM
  #36
oldbird1965
I hope you enjoy it when you get back, at least that lake is back to being full after a long dry spell
Old May 1, 2011 | 08:45 AM
  #37
albran's Avatar
albran
Let us know what the alignment shop finds.
<O</O
I didn’t read all the post.
When did you change the axles/tires?
<O</O
It’s a shame but tires may look NEW but if they are much older than 5yrs.
They are GOING to cause trouble!!
<O</O
ab
Old May 1, 2011 | 08:55 AM
  #38
oldbird1965
The axles were changed from 6K's to 7K's before I bought the camper. I replaced the rear axle when I broke the leaf springs and bent it. My tires never get over a year or so old before I blow them up, so no problem with old tires. Tomorrow I'll call to see if I can get an alignment appointment.
rvpuller
All Things Towing
Jun 1, 2016 06:28 PM
porthole
6.7L Power Stroke Diesel
Jun 24, 2015 12:28 PM
RV_Tech
All Things Towing
44
Jan 28, 2015 06:40 AM
Irelands child
All Things Towing
24
Oct 19, 2014 08:07 AM
porthole
84
Sep 26, 2014 10:22 AM
