1978 - 1996 Big Bronco
Part Name???
Old Mar 20, 2003 | 09:03 PM
The Tree's Avatar
The Tree
Part Name???
On a 1978 Bronco what is the name of the piece between the Rear-end (Ford 9") and the U-joint on the driveshaft? Is it the pinion flange I am trying to replace it and it is a little hard when you don't know what to ask for? Can I use one off a truck?
Also is the 351M a big block engine?
Thanks
Greg (a.k.a. The Tree)
Old Mar 20, 2003 | 09:19 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Part Name???
If it's the part that the u-joint fits in, and is held on with a large nut, then yes it's called a pinion flange.
The 351M and 400 are considered to be small blocks. They are based on the 351 Cleveland block.
Good luck with the Bronco. And yes, a pick-up of the same vintage will have the same rear diff parts (Ford 9").
Old Mar 20, 2003 | 10:23 PM
steve83's Avatar
steve83
Part Name???
Actually, it's a "yoke". The "flange" is a flat disc with threaded holes in it, used from ~'89-up.
Old Mar 20, 2003 | 11:50 PM
Mil1ion's Avatar
Mil1ion
Part Name???
Engine Description
IDIDieselJohn
16
Jun 28, 2022 06:28 AM
mxer0022
Sep 9, 2016 06:58 AM
professor90
New Member Introductions
Apr 27, 2015 02:07 PM
jdigio1960
Mar 2, 2011 09:41 PM
Greywolf
Tennessee Chapter
21
Mar 18, 2006 04:44 AM
