Traveling
Old Apr 25, 2011 | 06:11 PM
MHammer21's Avatar
MHammer21
Traveling
Gents,
Planing some pretty long road trips this summer towing my 5th and wanted to ask...
What are some of the replacemnet parts I need to get on hand to avoid being abandoned on the side of the road and approx which is most important as well as associated costs. I appreciate your wisdom and undertsand that different folks may think one is more important than the other, so just looking for a decent list.
Thanks again!!
Old Apr 25, 2011 | 06:20 PM
427 fordman's Avatar
427 fordman
Most important, cps. I carry 2. Otherwise, I just carry some spare oil, and I do have a spare idm along also. Lots of tools. Maybe a fuel filter, I don't though. A way to pull codes would be nice if you can. I never had, but now have a scan gauge. They are a couple hundred bucks though.
Old Apr 25, 2011 | 06:30 PM
MHammer21's Avatar
MHammer21
Thanks Darin. I'll start looking for a CPS...
Old Apr 25, 2011 | 06:46 PM
427 fordman
buy one from ford or ih. They are only about 25 bucks. Don't get a parts store one
Old Apr 25, 2011 | 06:50 PM
chicagodragon's Avatar
chicagodragon
hey darin, did you get your colum mount for the scangauge?
Old Apr 25, 2011 | 07:09 PM
427 fordman
Ya, I got it. Still gotta put it in though. Gauge and pod just sitting at the shop.
Old Apr 25, 2011 | 07:28 PM
fordpride's Avatar
fordpride
Fan belt........
Old Apr 25, 2011 | 07:44 PM
tjbeggs's Avatar
tjbeggs
Yep Serpentine belt and both a ribbed and smooth idler pulley. Pretty much if you have spare parts carry them. I keep an IPR, IDM, PCM, CPS times 2, Belt, both pulleys I mentioned and will have a vacuum pump, Fuel filter, and some others added here this summer.
Old Apr 25, 2011 | 07:56 PM
427 fordman
Yeah, for sure a belt, forgot I've got one of those. I should get a couple pulleys..
Old Apr 26, 2011 | 10:47 AM
MHammer21's Avatar
MHammer21
Are the Pulleys Ford parts as well? What can i expect to pay for em'?
Thanks for all of the info Guys...
Old Apr 26, 2011 | 10:59 AM
427 fordman
I carry some fuses too. My fuel heater is still plugged in, so I have maxi and mini fuses along.
Old Apr 26, 2011 | 11:13 AM
Robbgt's Avatar
Robbgt
don't forget to bring the appropriate torx to fit the pulleys. obvious I know, but I'd forget...
I got motorcraft pulleys from amazon.com I can get you links later if you like
may want to throw a roll of that "hose mender" tape in the toolbox. cheap and extra insurance
Old Apr 26, 2011 | 11:18 AM
MHammer21's Avatar
MHammer21
Wouldn't put it passed myself either. Last Dry Camping trip I turned around and went home for my BBQ and when I got out to the site and unpacked I had left the propane bottles sitting on the counter at home...
Old Apr 26, 2011 | 11:27 AM
Robbgt's Avatar
Robbgt
Grooved
Amazon.com: Motorcraft YS268 New Idler Pulley for select Ford models: Automotive
Smooth (couldn't find motorcraft, gates is good stuff, probably better anyways)
Amazon.com: Gates 38022 Belt Drive Pulley: Automotive
I think if you order them both at the same time, you get free shipping also
Tensioner if you're looking for that (note: 'updated' design, longer arm, do not use factory washer, bolt will recess into arm. some like the upgrade and some would rather do the SD tensioner mod...)
http://www.amazon.com/gp/product/B000C2UI0I
Oh, another 'duh' one... if you don't have on board air, or a compressor (may be worth investing in an inexpensive 12v one that can plug into cig lighter) check all your spare tire pressures too... nothing worse than getting a flat, and having a 'flat' spare.. just trying to think of stuff I know I'd forget...
Old Apr 26, 2011 | 11:41 AM
tjbeggs's Avatar
tjbeggs
The pulleys can be bought at any parts store as well.
