e40d rebuild upgrade questions
Old Apr 25, 2011 | 03:57 PM
|WYG|SS's Avatar
|WYG|SS
my friend is getting his e40d rebuilt on his 94 f150 that has the 5.0l with 200k on it but only 10k on rbuilt motor.
his input shaft seal began to leak and so he took it in and he told them to rebuild the transmiision while they had it out. well they sent it some place to get rebuilt and the place said luckly he didnt just replace the seal because the transmission wouldnt have lasted much longer.
now they asked him if he wants to upgrade a couple things like from a 3 pin to 4pin(i dont know what this means, can someone explain), and also if he wants better clutches and gears. i told him go with the better gears for towing.
its like an extra 200$ or 300$
Old Apr 27, 2011 | 04:03 PM
mustangman's Avatar
mustangman
yeah the e4od 95 up had a lot of upgrades,, for sure in 95 had a much bigger fluid oil pump, some cast iron replaced aluminum gear holders think they are planetarys? iwonder if the trans already had the roller bearings in the center support for that year
Old May 14, 2011 | 12:04 PM
mikeismadness's Avatar
mikeismadness
transmission has already been rebuilt but upgrading to steel planetarys would be a huge upgrade
Old May 21, 2011 | 12:36 PM
l-m tech's Avatar
l-m tech
i would of also installed a 42 element intermediate sprag, new bushings and a sonnax sure cure kit
Old Jun 8, 2011 | 11:11 PM
PDR60's Avatar
PDR60
The sure cure for sure. It will make a huge difference. The pump needs to be an F5 casting as its higher output. The steel planetary sets are also a great addition. I spent $1300 on parts for mine and am getting ready to pull and overhaul it.
bobj49f2
May 30, 2014 09:37 PM
sand_fiend
Jul 30, 2012 10:05 AM
Canus
Jun 10, 2012 09:51 AM
adambomb
Sep 7, 2009 04:13 PM
Kallie
15
Oct 21, 2006 06:23 PM
