Transmission ID - manual 4-speed OD
Old 04-25-2011, 12:53 PM
DHCowdude's Avatar
DHCowdude
DHCowdude is offline
Hiya'll!
Have the tag numbers (or as far as he could tell) off of a Ford toploading 4-speed w/ OD tranny from back a ways. The guy isn't sure whether it may have been pulled from a truck or a car, but he thought it came from behind a 302.
Here's what he said he saw:
top line: RUG - CLJK 28
lower line: D8UR F (or E) A0690
It's cast iron cased, but apparently there may be lighter-duty bearings/gears in the car version than the truck version? I'd like to bolt this behind a 300 6 cyl in a van/truck. Any ideas? And would splines/pilot bushing/lengths be the same for all?
Thanks in advance Fordies!
Old 04-25-2011, 11:48 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,632 Likes on 1,331 Posts
They say the gears are cut thinner. It appears the bearings are the same as the performance toploader. Ratios include a big gap 2nd to 3rd. Depending on your gears and tires, it will be ok or it will suck.
Toploader Imposters
Toploader 4 Speed Transmissions
I had one as OEM in my '85. Iron case, side mounted external shifter. Squeeling bearing somewhere, never fixed it.
I'd rather have the Mazda 5er ratio wise, or the ZF strength wise.
Old 04-26-2011, 09:44 AM
DHCowdude's Avatar
DHCowdude
Thanks - I just KNEW one of you guys would know what this was. So looks like it's a Granada tranny, and likely not that hot for behind the 300 in a pickup or van setup - eh? Too light of bearings and thin gears from what I just read thanks to your link. Crap. but better to know now than when it halfway between here and Albuquerque and it's innards are lying all over the road... :-/
Old 04-26-2011, 12:53 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Might be ok for a 300 powered truck running down the highway with a somewhat lighter load. Even at their best, the 3 OD was never a great trans for heavy loads or trailer duty.
Old 04-26-2011, 03:10 PM
DHCowdude's Avatar
DHCowdude
Yup.. But that's pretty much what it'll be doing once/twice a year. Angle-iron 4.5x8' trailer with no springs and a full load on each. Course it's a to/from deal most times..
Best to keep looking for an actual truck OD I suppose..
Old 04-26-2011, 03:17 PM
Rogue_Wulff
For heavy loads, I'd steer away from the OD unit completely. Like I said, at their best, they weren't very well suited for *actual* work.
The later M5OD is a much better design, and has an extra gear between low and direct, plus the OD. The ZF 5 speed is the holy grail of OD trans (manual) to fit a 300, but they are not real common.
Old 04-26-2011, 03:25 PM
DHCowdude's Avatar
DHCowdude
Ahhhh.. gotcha..
- but would that bolt up to an older carbureted engine and fit into an older truck/van? I'm looking at likely either having to jerk an automatic or a granny-gear standard to replace with the OD manual for fuel mileage. 14/16 MPG's just ain't gonna cut it for my uses with a truck and I see no way to reach anything like 20+ without the OD?
And I see one of the big Pine trees just lost another huge branch while I'm typing this.. dang she's windy out there today!
Old 04-26-2011, 03:33 PM
Rogue_Wulff
You won't touch 20+ MPG towing a trailer, with or without OD. I doubt even a new truck could do that. At least not regularly.
A granny 4 speed and gearing in the 3.00-3.25 range would give the best overall power/MPG, especially for towing a trailer. 2.75 or 3.00 for best MPG, 3.25 or 3.50 for best towing. Depending on how heavy the truck/trailer will be loaded, the 3.25 would likely be the better overall choice.
Golden Helmet
27
01-19-2015 07:21 PM
V AZARIAH V
36
09-28-2014 06:26 PM
FordTruckfan89
09-14-2014 03:02 AM
Macs1964F100
15
04-14-2014 11:43 PM
DHCowdude
19
05-16-2012 12:32 AM
Quick Reply: Transmission ID - manual 4-speed OD
