Brake System Bleeding Tool
Old Apr 25, 2011 | 08:14 PM
woodnthings's Avatar
woodnthings
Originally Posted by danskool
What braided lines did you purchase?
I got a full set from Clay at Riffraff Diesel. These little jewels come in different colors. I went with smoked for mine. The color looks to be an outer sleeve over the braided hose. Nice quality and they can be made to any length according to Clay.
Old Apr 26, 2011 | 02:49 AM
Nsaan's Avatar
Nsaan
how did the braided lines change your pedal feel? Solid as a rock now? I ask because on my f450 I have a spongy pedal, I know my power steering pump leaks a bit from the cap and the last time I was under the dash I noticed some fluid coming in through the shaft on the brake master cylinder. The truck had a bad habit of puking the fluid from the power steering pump for the longest time. I had been using power steering fluid... the A-holes at autozone told me that was what I wanted. I found here that is not true and it doesn't leak and puke as much anymore. I am thinking the pump is weak and it is making the brakes weak.
Not to Hijack the post, the tool is awesome. If I didn't have brothers or a kid to pump it for me, I know what I will be building.
Old Apr 26, 2011 | 06:07 AM
woodnthings
The pedal is solid, I will find out how much more when towing this summer. Just driving around there is a slight difference, but it could also be from doing the flush/bleed procedure.
Old Apr 26, 2011 | 11:34 AM
SpringerPop's Avatar
SpringerPop
Do you guys first empty the master cylinder by flushing out the system with air pressure, or do you attempt to never let the reservoir get to the bottom, and use a turkey baster (or similar) to get most of the old first?
Pop
Old Apr 26, 2011 | 12:11 PM
Fat Diesel's Avatar
Fat Diesel
Pop- I use a mighty vac to get most of it out first. But I do not let it go dry. It wouldn't be the end of the world, but I don't want any more air in there than necessary.
Old Apr 26, 2011 | 12:35 PM
SpringerPop
Makes sense.
No air in, none to get back out.
Pop
Old Apr 26, 2011 | 01:30 PM
woodnthings
Same for me, pull out as much old fluid as I can, then let the lines bleed until plenty of clear fluid comes out.
Old Apr 26, 2011 | 01:56 PM
kccatpower's Avatar
kccatpower
Ken thank you for posting pics, my wish list continues to grow
Old Apr 26, 2011 | 03:15 PM
woodnthings
No problem!
Old Apr 26, 2011 | 05:38 PM
danskool's Avatar
danskool
Go Bills !
x2.. Thanks Ken.. On my already huge list. my freakin cab lights are still under my desk. A year now.
Old Jan 7, 2012 | 06:23 AM
jetdoc's Avatar
jetdoc
You know, threads like this is why I spend the twenty bucks to keep this site up year after year...
Thank you Ken. Excellent job, I will be making one of these today.
Old Jan 7, 2012 | 06:45 AM
caverjoe's Avatar
caverjoe
Yep!!! The $20 a year does not even scratch the surface on the amount of money this site has saved me.
Nice job.
Old Jan 7, 2012 | 07:01 AM
  #28
tewferford's Avatar
tewferford
Good morning, just happened to stumble onto this thread, and was thinking about the cap setup. Would it be possible to use one of those beveled rubber stoppers, that they use in chemistry labs, and a couple of zip ties to hold it in place, or do you think the psi would be too much? Seems to me, this would be a good way to use this on many different vehicles without the need to buy many different caps.
Old Jan 7, 2012 | 10:23 AM
  #29
danskool's Avatar
danskool
Go Bills !
Don't really need to seal the cap. Add fluid to the reservoir and spin on a modified cap with a male disconnect on it. Adjust the air compressor for 10psi and start cracking bleeders. As long as the air compressor can supply the more volume of air than what the cap is leaking then you will maintain enough pressure to push fluid. The last flush i did i didn't even use the sprayer bottle. Do one caliper at a time. There is plenty of fluid in the reservoir to get all the old fluid out.
Old Jan 7, 2012 | 02:20 PM
  #30
Bonanza35's Avatar
Bonanza35
Great write up. Never thought of this but I sure will use this on my next brake and line replacement.
Chet
woodnthings
48
Jul 4, 2018 06:10 PM
woodnthings
28
Dec 5, 2014 08:57 AM
woodnthings
27
Jul 9, 2014 07:07 PM
woodnthings
32
Mar 27, 2012 08:54 PM
woodnthings
103
Mar 16, 2011 07:36 PM
