extended length shocks
Old Mar 20, 2003 | 07:39 PM
nick11082001's Avatar
nick11082001
is it possible to use extended length shock absorbers with extra travel as a way to get a small amount of suspension lift? im looking at Pro Comp's ES9000 extended length shocks with 15" travel.
Old Mar 20, 2003 | 07:41 PM
nick11082001
i forgot to mention that i have an unlifted 1982 F150 4x4
Old Mar 20, 2003 | 08:34 PM
steve83's Avatar
steve83
Shocks don't lift the truck. For that, you need springs or spring shims to push the suspension away (but you lose downtravel) or bracketry to push the suspension away (labor-inten$ive).
Longer shocks will just allow the suspension to travel to its mechanical limits, including breaking the brake lines.
Old Mar 20, 2003 | 08:46 PM
nick11082001
ok, well, so much for the extended length shocks, does anybody in here reccomend air shocks or have had good luck with air shocks?
Old Mar 20, 2003 | 10:17 PM
steve83's Avatar
steve83
The airbags on those shocks behaves like a spring shim, so again, you lose downtravel. They leak frequently and are expen$ive. Why do you want lift? What do you do with the truck?
Old Mar 28, 2003 | 06:11 AM
Pkupman82's Avatar
Pkupman82
ceetwarrior
15
Mar 5, 2020 07:01 AM
MDSLIGHT
Mar 28, 2014 07:53 PM
montey2005
6.7L Power Stroke Diesel
Jun 30, 2012 10:08 AM
hmbrewr
Jun 23, 2012 05:47 AM
