Navistar found a way to make more power.
they directly injected the sucker and ford called it the PSD.
start with one of these if you want SERIOUS power and have some $ to play with.you'll be way further ahead.
you guys need to enjoy the simplicity and work ethic of the idi more hehe.
these rigs are supposed to me money makers. .......now if i can just stop putting $ into mine for a bit already haha.ok,so iv got the itch a little too.
If and when one day i build a idi to take 15+lbs of boost im gunna do a compound setup with a low pressure turbo and a high pressure turbo the high pressure one is going to be the stock ats then the low pressure will be a hx35 cummins 12valve turbo this should with enough fuel give nice spool and good boost with little smoke and great fuel economy
