Hellwig Rear Sway Bar Success Story
Usually, one end is welded to the frame, the other bolted to the axle.
Another bar which goes side-to-side is a panhard (or track) bar that would keep the axle in line with the front wheel track.
My 2WD has neither, but I think aftermarket kits are available.
Traction bars prevent the leaf springs from wrapping up improving traction.
Ford only installed them on the 4wd model because 4 low is really the only time the rear axle will wrap bad enough to cause wheel hop. Not many folks are going to modify or use their 2wd Ex in a manner that produces wheel hop so most don't need a anti-wrap or traction bar on the 2wd Ex.
Do they bolt on?
smoky_diesel
6.7L Power Stroke Diesel
06-07-2016 12:55 PM
Sous
38
05-06-2016 07:25 PM
