Hellwig Rear Sway Bar Success Story
I bought a 2003 Excursion last month and immediately noticed suspension and steering problems. First thing I did was replace the stock shocks and steering stabilizer with Ranchos. That helped a little. Then I installed the Roadmaster Active Suspension. That helped a little too. Finally, I installed the Hellwig rear sway bar yesterday. BINGO! That helped A LOT! My X drives like a brand new vehicle now. The body roll is gone and the squirrely steering is finally gone.
I'm sure there's some combined effect from the new shocks, RAS, and sway bar. However, I must say that the Hellwig rear sway bar had by far the greatest effect on the drive-ability of the vehicle. I highly recommend this upgrade to anybody who doesn't have a rear sway bar yet. I just wish I would have done it earlier.
on
Hey jh, I also have the Michelin AT/2s, the hellwig, Bilstein stabilizer and a KYB gas-a-just at each corner. Used 12mm offset rims when replacing the factory stamped steel, pushed the track out a couple of inches. Overall these trucks can be tamed into handling like a Camaro. I've heard that comment from a couple of guys I let drive mine.
https://www.ford-trucks.com/forums/1...bar-links.html
Aint it cool how much nicer these rigs are when they handle better?
As has been recommended on different Excursion forums since at least 2004, the Hellwig is but one piece of the puzzle to upgrading the woeful OEM suspension Ford used on the 4x4 Excursions. If you find you might want more, look into upgrading your front and rear springs.
Stewart
Thanks Stewart H! A couple of questions for you:
1. What kind of front and rear spring mod do you recommend? Changing the springs hasn't been "on my radar" yet, but I'm always open to new ideas.
2. On the Hellwig sway bar, what kind of regular maintenance issues have you dealt with (if any)? Have you ever discovered fasteners getting loose, bushing wear, or anything else?
For the rear, B codes are used almost exclusively. Sometimes people will mod their B codes (aka modded B codes) before putting them on.
Here is some extensive reading for you to "catch you up" on the spring mod: https://www.ford-trucks.com/forums/7...s-for-you.html
Stewart
The Excursion comes Stock with a "traction bar" So yes, many people are using a traction bar in conjunction with a rear hellwig anti-roll bar.
