The camper thread! Pulling, using, equipment, maintenance!
#4306
Must be the season for propane hoses. Our 2017 Keystone Passport 2810BH needed one of the propane hoses replaced. It was split all to heck already. Strangely the one right next to it is perfectly fine.
Replacing them both tomorrow after work with some upgraded stainless braided reinforced hoses.
#4307
#4308
#4311
The following users liked this post:
#4312
I read their instructions, and decided to do it my way. I measured how far the end of the bar was from the frame with the old jacks and duplicated that amount with the new jacks. Takes any variation in jack design out of the equation. Felt the same towing to me with the new jacks.
#4313
#4314
#4315
Putting an actual fan in the hole is an option. I purchased my enclosed car trailer in 2016. Then in Jan of 2018, I had to purchase a new vent cover as the factory one was falling apart.
It fit well and was easy to replace in the 15x15 (14x14?) opening. They had some that also came with 12v fans, but at the time I just wanted to keep the water out.
An A/C would have been nice, but it only works on 120v, and its a little out of my price range.
#4316
#4317
You can trailer with it open, you can use it when raining, it has a ceiling fan feature, thermostat feature on the remote. And moves a lot of air.
https://www.airxcel.com/rv/maxxair/p...maxxfan-deluxe
#4318
I replaced one of my standard vent fans wit the Maxxfan Deluxe.
#4319
Pretty cool as hey have a rain sensor and will auto close in the event of rain. They have a thermostat that has auto and manual settings for temperature and humidity. They also auto open/close when turned on, so no cranking of the handle. Can also be manually opened and closed.
Dicor works well for the sealing area around anything that goes through the roof. They have two kinds, one flows better than the other, I forget the actual designation.
#4320
I have fantastic fans in the coach. If I put a cap on them, I could have them open while going down the road but I don't find it necessary.
