tranny problems 5 spd
Old Apr 23, 2011 | 06:15 PM
rquinlans's Avatar
rquinlans
transmission shelled out on 93 f 150 5 speed. had a month old clutch and new slave cylinder in it. Picked up a used 5 speed , supposedly a good one , installed with the newer slave . Bled clutch , have a ton of pedal , the truck rolls free when clutch engaged , can start the truck in gear with clutch engaged , and the gear works normally engaging when the clutch is let out. when start in neutral cannot get it into gear.
WTF , bad transmission ? Any thoughts or advice appreciated.
When the old tranny crapped out could it have damaged the clutch disc ? The old tranny somewhat locked up and even when in neutral has something going on inside , kind of dragging. limped it home in fourth gear and didn't hear anything going on that would indicate some kind of damage.
Old Apr 23, 2011 | 08:17 PM
jas88's Avatar
jas88
Have you tried pumping the clutch pedal about 5 times in neutral with engine running, and then see if you can get it into gear? If it goes, your clutch system still has air in it.
Old Apr 23, 2011 | 09:57 PM
rquinlans's Avatar
rquinlans
yep , tried that , pulled the yoke out and watched while in neutral and had circulation of fluid both with clutch in and out. seems it is not completely releasing , maybe a damaged disc , or slave that is not fully extending. pull it out again tomorrow and check it all out , ahh crap !
Old Apr 23, 2011 | 10:56 PM
big-ugly's Avatar
big-ugly
Sounds like your slave is weak to me. I am kinda having the same issue with my 95 right now. Overfilling the reservior by about 1/8" helped me a little, but the problem is still there. I burned my clutch up pretty good last weekend, so mine is all my fault.
Old Apr 24, 2011 | 02:37 AM
bent-1's Avatar
bent-1
If it's a new clutch disc I make sure the splines are clean (I use brake cleaner & q-tips). Sometimes there's a laquer like substance on the splines that causes the disc not to glide on the splines freeley. Follow shop manual on lube for splines & throwout bearing sleeve.
Old Apr 24, 2011 | 08:14 AM
rquinlans's Avatar
rquinlans
yeah , i agree with the above posts , going to pull it all and put in new clutch kit and slave and be done with it , probably should have done that yesterday. Murphy was hanging around my garage yesterday ! thanks for the input guys , its always appreciated
Old Apr 24, 2011 | 09:49 AM
big-ugly's Avatar
big-ugly
Murphy got bored of hanging around my garage and decided to bother you, eh? Good luck with your replacements.
