What year did F350s get 5-speeds?
Old 04-23-2011, 12:42 PM
irhunter's Avatar
irhunter
irhunter is offline
Hi,
I am interested in getting an F350 4x4 and would like to know what model year the 5-speed was introduced. Was the first 5-speed a ZF S5-42?
Thanks,
Roy
Old 04-23-2011, 12:50 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
Yes, thats the correct model number for the first 5 speed. It was introduced in either 87 or 88, im not sure
Old 04-23-2011, 01:02 PM
irhunter's Avatar
irhunter
irhunter is offline
Thanks Blue,
I have another quick question for you about the ZF; this one is about what I'd call "shift quality."
I am familiar with the old-school 4-speeds (e.g., in my '61 and '67 IH light trucks)...the shifting was super-long-throw and more than a little vague. Know what I mean?
I also work at a place with a 2000 F250 with the 6-speed manual. I found that tranny had a pretty short throw and "tight" feel to the shifting.
How would you describe the shifting of the early ZF? More like the 2000 F250 or the '67 Travelall?
Thanks,
Roy
Old 04-23-2011, 02:32 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
87 was the 1st year for the zf5 s42. And they are tighter feeling then the cast iron trans' but not quite as tight as the zf6
Old 04-23-2011, 06:10 PM
irhunter's Avatar
irhunter
irhunter is offline
Thanks Brad,
How does the S47 shift compared to the S42?
When did the ZF6 come in?
Roy
Old 04-23-2011, 07:59 PM
Blue Rebel's Avatar
Blue Rebel
s47 is pretty much the same trans as the s5-42, just minor upgrades. the 6 speed came in w/ the superduty in 98
Old 04-23-2011, 08:17 PM
irhunter's Avatar
irhunter
irhunter is offline
Thanks Blue.
Old 04-23-2011, 09:22 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
1987 first year 5 speed as a *option*, 4 speed as base.
1988 first year for base 5 speed, 4 speed droped out.
Old 04-23-2011, 09:30 PM
irhunter's Avatar
irhunter
irhunter is offline
Thanks IDI,
It seems I'll be in the market for a crew cab with the early 5-speed. I need overdrive and don't want it to shift like my Travelall.
Roy
Old 04-23-2011, 10:49 PM
Onus's Avatar
Onus
Onus is offline
The 5 speed is tighter than the 4 speeds for sure. On my 91 i know for sure where all the gears are, on the 83 i have to assume that there is a gear in that spot and just jam it in. The zf 5 still has quite the shifter throw as do all truck transmissions.
Old 04-24-2011, 07:49 AM
Diesel_Brad
Originally Posted by irhunter
Thanks Brad,
Roy
The 42 shift better than the 47 IMHO. but it doesnt matter, unless you are getting a 96-97 your will be getting a 42.
99 was the 1st year for the zf6
If you travel at any speed over 50mph, you will want OD
Old 04-24-2011, 10:05 AM
irhunter's Avatar
irhunter
irhunter is offline
OK Onus and Brad,
Long-throw is fine; I have just come to the point where I find "vague" shifting to be something to be avoided when possible. I did find the 2000 6-speed to be a very nice-shifting tranny.
Yes, overdrive for sure. Whatever I end up with will get a Cummins eventually and they, like the Navastar diesels, don't spin any too fast.
Roy
