Turbo rebuild, now what?
Center
Jim, Thanks, I think that is the route I will go.
The center section seems fine. I was going to just rebuild the turbo and out a WW on while I did the pedastal Orings, everything seemed fine, this was just going to be a PM deal.
Anyone else think i should rebuild it, or toss it?
thanks much
thanks much
thanks much
thanks much
Edit; How's your exhaust housing look???
Mine looked the same. Only reason I'm not rebuilding mine is cause all the in and out play from the thrust bearing failing wore out the compressor backing plate. Gives me a reason to upgrade! I really think the exaust wheel damage was caused by heat. Reason being the housing on mine had no sign of debris passing through it. And the way all the fins are peeled back leads me to think it's heat. Kinda scary. In fact if I'm not mistaking when looked at where the fins where damaged compared to the housing that's right where the exaust comes in from the babys but. I think the exaust wheel is stainless, maybe. I know it's not magnetized but if you think about a cherry red or orange flame blowing in the ends of that wheel turning at those high of speeds I could see how it would peel it back. If I'm wrong tell me, this is what I've
Conclude on mine. If it's wrong I'd like to know what causes this!
I have some van turbos if that helps you.
Turbo
Going to give Clay a call Monday morning and discuss all my options, will follow up from there. Lots to do on the truck yet cleaning wise, ccv is in, another coat of PB on the frx and hpx plugs, fuel bowl is resealed, lots going on yet. taking some pic's as I remember, will post up the whole thread later on, thanks all.
