how much weight?
Old Apr 22, 2011 | 02:38 PM
KrautBurner's Avatar
KrautBurner
Question how much weight?
I have a 1977 F250 Ranger SuperCab 8' bed, with a 460 4bbl / c6
I'm thinking about picking up a slide (truck bed) in camper
and wondering how much weight the ole' truck can handle
any info would be great.
Russ
from Post #15
Originally Posted by KrautBurner
I got under the truck and identified those springs as Helwig 2505 (2500lb helper springs)
not sure if they add 2500 lbs or make it a total of 2500lbs
also figured out that I have a 3.54:1 rear end
Old Apr 22, 2011 | 04:37 PM
Sleepy445FE's Avatar
Sleepy445FE
There were several GVWRs available. You would need to know which you have to know what the actual rating is. Mine is a 7600lb GVWR and I've put 2k in the bed and and it squatted Maybe 2" if that. The susp. seems like it would take much more. I have overload springs though so it's not apples to apples. I think you'll be fine with that little camper regardless. Just make sure your brakes are in good working condition.
Old Apr 22, 2011 | 05:09 PM
KrautBurner
would I use the GVWR that's inside the door?
the truck weighed about 5600lbs with me, my wife, and kid, as well as both fuel tanks full
I know the front brakes were just done last year.
Old Apr 22, 2011 | 05:39 PM
Sleepy445FE
Yeah the tag inside the door jamb should have the gvwr. It should tell you front and rear weight ratings. If you can get it on the scales you can check what it weighs over the rear axle empty and then subract that from the rear rating and you'll have your number.
Old Apr 24, 2011 | 08:34 PM
KrautBurner
6550 GVWR
3550 FRONT
4000 REAR
THAT SEEMS KINDA LOW. DON'T IT?
Old Apr 24, 2011 | 10:43 PM
78 PEB's Avatar
78 PEB
Yeah, it does...........Is that off of the door tag? Is it the correct tag? Does the VIN match the frame # and title etc? That only gives you 900lbs to work with if it is..............
Old Apr 24, 2011 | 10:49 PM
KrautBurner
The day I weighed it. I had just dumped about 800 lbs at the dump.
And when driving there. It didn't feel any different than empty. Even the brakes.
I wonder if the scale was off?
Old Apr 25, 2011 | 12:20 AM
KrautBurner
6550 GVWR
3550 FRONT
4000 REAR
it was the door tag.
is 6550 a low number?
or just compared to what I was on the scales?
how much should these trucks weigh?
I think the title said like 4600 lbs
Old Apr 25, 2011 | 12:47 AM
Sleepy445FE
I don't know for sure how many GVWRs there were in 77, but in 76 there were 10 different GVWRs listed for F250 4x2s ranging from 6200lbs to 8100lbs. So it's on the low side of the available options but is not anything unusual. As you've seen, they can do a lot more than they're rated for.
My F250 4x4 has a 4500lb curb weight on the title, but I tip the scales at 5300lbs with me in it.
Old Apr 25, 2011 | 09:02 AM
78 PEB's Avatar
78 PEB
I'd say that if you have found a camper you want, buy it................load it up, make a few short "test runs" with it and go from there. You may have to add a few leaves to the springs to get the truck to handle it comfortably or you may not. It could be as simple as adding some air shocks or air bags to it. None of which are all that expensive. The biggest issues with a slide in camper are how you load it down once its in the truck and wind due to a higher profile. Just keep all of this in mind and you will be fine...........
Old Apr 25, 2011 | 01:01 PM
KrautBurner
sorry for the huge picture
so,
the springs are the only real difference with the different GVWR's?
I am pretty sure it's got the factory overload springs. (they look really hefty)
looks like this:
not this:
Last edited by KrautBurner; Apr 25, 2011 at 01:02 PM. Reason: sorry for the huge picture
Old Apr 25, 2011 | 01:07 PM
78 PEB's Avatar
78 PEB
I dont think that they are factory overloads...............They look like an aftermarket set up to me. But looks like there is enough springs there to handle it to me. I don't suppose you have any idea what the camper weighs do you?
Old Apr 25, 2011 | 01:17 PM
KrautBurner
that's the big problem right now,
the camper has no badging (just one plate with a serial number): 105*667*1005
and a title that says:
Use Class: CMP
Mod YR: 67
Make: FBRT
Series & Body Type: 11CBR
the guy called it a 1967 11ft FiberTop Camper
I can't find any brand called "fibertop"
it looks like a SCAMP if they were to make a cab over truck camper
the owner hauled it in a 95-96ish F350 4x4 (and said it had no trouble)
my other issue with loading it up and testing it out is the fact that I really need new tires, my truck came with some 20 year old 9.75x16.5 tires (on 16.5 wheels)
I've already picked up some 16's, but am a little short this month to pick up tires)
i'm currently looking for some used "E" rated tires
Old Apr 25, 2011 | 01:26 PM
KrautBurner
now that I've looked a little,
they look alot like these 1967-1997 Ford F250 Helper Springs, F350 Overload Spring - Hellwig
Old Apr 26, 2011 | 03:33 PM
KrautBurner
