Custom gauge cluster
Old Apr 21, 2011 | 10:07 PM
Poison Oil Racing's Avatar
Poison Oil Racing
I thought I would post an update to my custom stainless steel dash.
I have it fitted into the main part of the dash and just need to tweak it a little bit and then finish cleaning it up and cut the holes for the gauges.
Anyway, here you go:
This is right after I got it home
Test mounted in the dash:
Mark
Old Apr 21, 2011 | 10:09 PM
devino246's Avatar
devino246
Nice What type or welder did you use?
Old Apr 21, 2011 | 10:12 PM
bucks77ford's Avatar
bucks77ford
Very Nice.
Old Apr 21, 2011 | 10:39 PM
Poison Oil Racing
TIG welder.
I am pretty pleased so far.
Old Apr 21, 2011 | 10:41 PM
devino246's Avatar
devino246
Originally Posted by Poison Oil Racing
TIG welder.
Thats what I figured. Tricky stuff.
Old Apr 22, 2011 | 03:34 PM
ChaseTruck754's Avatar
ChaseTruck754
Looking good. I'm patiently awaiting more pics as this thing will let me know what my idea would look like if I got off my butt and did it...
Old Apr 22, 2011 | 08:04 PM
Poison Oil Racing
well if you like it when I am done, we can talk about making you one.
Mark
Old Apr 25, 2011 | 06:13 AM
Poison Oil Racing
here are a couple more pics. The gauge holes have been drilled. Still have to cut out the heater control and radio panels as well as the wiper and headlight holes.
Old Apr 25, 2011 | 01:36 PM
ChaseTruck754
Mark
Thanks for the offer but I'll make mine. Just need to finish a few other things on the truck 1st. Gauges are a low priority now so I haven't messed with it. I don't have the $$ to pay other people to build things for my truck. Especially stuff I can do myself.
What are you using to cut the holes in the stainless? I have stainless around to make one but I'm thinking I'll make mine out of aluminum. Easier to work and I like the looks a bit better.
Old Apr 25, 2011 | 01:53 PM
Poison Oil Racing
a bi-metal hole saw.
Old Apr 25, 2011 | 01:56 PM
ChaseTruck754
and they work well? I HATE working with stainless because it eats saws, etc. - even with lots of lube and super clow speeds. I usually end up cutting it on the plasma table and shear so I don't have to mess with hole saws, etc.
Old Apr 25, 2011 | 02:00 PM
Poison Oil Racing
go slow, use LOT'S of lubricant. No problems.
Old May 12, 2011 | 09:05 AM
Poison Oil Racing
here is an update photo for you.
I have test fit all of the gauges. I need to install the turn signal and high-beam lights, wire it all up and I am ready to install.
Will hopefully be done this weekend.
Mark
Old May 12, 2011 | 02:57 PM
BoomerTexas70's's Avatar
BoomerTexas70's
Wow, that is sharp. How much time did you put into making it and what manufacturer are the gauges you have? With what i would like to to to my interior that would look really sharp.
Old May 12, 2011 | 03:52 PM
xran's Avatar
xran
I never knew you could get an autometer clock, that's a great idea!
are you going to do the glove box in the same way? As someone else said above, I'm going to do something similar with the dash in my '74 but with Ali, I prefer the brushed Ali because it keeps the reflections down a bit more than polished stainless... even if the s/s looks WAY nicer...
I'm glad I didn't post earlier to say that your speedo hole wasn't central, because now I see why hahaha
