AOD ?
Old Apr 21, 2011 | 09:20 PM
82 F150's Avatar
82 F150
AOD ?
Is it worth paying to have an 82 AOD rebuilt, and does anyone know a good quote for one?
Old Apr 22, 2011 | 04:56 AM
Archion's Avatar
Archion
Veteran: Marine Corps
You are much better off finding a later model unit, preferrably 89 up. There were many case and lubrication upgrades. The best would be out of a 93 5.0 truck or van, it also had the beefier internals. Dont be surprised if most shops want to charge you @1500 just for a bench job.
Old Apr 22, 2011 | 08:07 AM
smashclash's Avatar
smashclash
does he need to look for an AOD that's specific to 4x4 or will a 4x2 one work just as well?
And would putting one from an 89+ be 100% plug and play compared to an older model such as an 86?
Old Apr 22, 2011 | 08:18 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
You will need to either save the output shaft or find one, they are 4WD peculiar. You will also need the shift lever from the older one if you go newer than 91, 92 up F series and Bronco went to cable shifter.
Old Apr 22, 2011 | 08:30 AM
Archion's Avatar
Archion
I was figuring if he had 4wd, he would look for a 4wd trans. The output shaft swap requires complete disassembly. With the expection of the shift lever it is a direct swap. If you are scavenging 2wd's in a pile, be mindful of the lengths of the transmission, some cars had a shorter output shaft and tailhousing. Remeber to flush the trans cooler and put in a new convertor.
Old Apr 22, 2011 | 01:49 PM
80FlareSide's Avatar
80FlareSide
Why would anyone ever go to a transmission shop when top end AOD rebuilds are $1,250 with free shipping?
AOD Transmission Remanufactured Heavy Duty Performance 4x4
Old Apr 22, 2011 | 07:05 PM
ctubutis's Avatar
ctubutis
Because going to a local guy (or business) who works on transmissions helps the LOCAL economy.
Old Apr 22, 2011 | 10:10 PM
82 F150's Avatar
82 F150
Anyways lol, its a 4x2 regular cab with 8 foot bed
Old Apr 22, 2011 | 10:23 PM
82 F150's Avatar
82 F150
Oh yea with a fresh 302 that I'm putting in tomorrow
Old Apr 23, 2011 | 08:25 AM
LARIAT 85's Avatar
LARIAT 85
Yes, I would say it *is* worth it to have your AOD rebuilt, as it is a pretty good transmission. I had my 1985 AOD rebuilt about 4 years ago for $1000, and that is with a brand new torque converter and a full 2 year warranty.
I was told by my friend who owns a transmission shop that it is very important to flush the radiator transmission cooler and lines out before installing the new rebuilt transmission. The reason being is because metal particles from the old transmission will be trapped inside, and you do not want to reintroduce that into your newly rebuilt transmission.
Also, make sure your throttle valve rod set correctly!
The throttle valve rod (or cable, on later models) directly controls line pressure on the AOD. It is a gold colored metal bar that is located on your carburetor throttle arm and connects to the transmission. If the TV rod isn't hooked up and set correctly, you can completely destroy your newly rebuilt transmission in a couple of miles!
Old Apr 24, 2011 | 03:52 AM
Ken Blythen's Avatar
Ken Blythen
I just took the AOD out of my truck two days ago & replaced it with a C6.
For someone driving long distance/high speed, the overdrive would make rebuilding an AOD worthwhile for fuel economy, (if an axle change isn't practical); but for slower and/or heavier duty use, I really think the C6 is the best choice.....much more durable without expensive modifying, much cheaper to rebuild when finally necessary, & simple operation (I like low-tech, high-reliability ).
I know the C6 doesn't have a lock-up converter, but an AOD modified for abuse doesn't either.
There is also the false impression that AOD's are lighter in weight than C6's, but in fact they weigh slightly (around 10lb) more.
Power consumption of both is pretty nasty compared to a manual, or even a C4.
Old Apr 24, 2011 | 01:47 PM
82 F150's Avatar
82 F150
Yea I do a lot of highway/long distance driving, I didn't think about that
Old Apr 24, 2011 | 08:34 PM
Archion's Avatar
Archion
If that 302 is the one on your profile pic, it has some aftermarket goodies maybe? you will need to do at least some of the upgrades to handle any real difference in power.
Old Apr 24, 2011 | 08:59 PM
82 F150's Avatar
82 F150
Well I'm not really wanting to hot rod, just my daily driver you know.
Eventually I want to put a/c back in it. Oh and I wasn't able to finish installation of the motor and trans but maybe tomorrow after work, can't wait
Old Apr 25, 2011 | 02:07 PM
82 F150's Avatar
82 F150
Yep your right I just got a quote for at least 900 dollars
