EBPV delete question
Old Apr 21, 2011 | 03:19 PM
rtazz17's Avatar
rtazz17
I read when removing the butterfly (when you grind out the top)and put in the 3/4 inch freeze plug,what do I use to hold it in place? I thought I read to use red loctite? Thats only good to 300 degrees right?Can someone tell me what to use.. I havent done it yet but getting stuff I need..Thanks
Old Apr 21, 2011 | 03:32 PM
rtazz17's Avatar
rtazz17
I dont have a welder so not an option
Old Apr 21, 2011 | 04:36 PM
23larry24's Avatar
23larry24
You could stake the plugs in using a hammer and chisel.
Old Apr 21, 2011 | 04:39 PM
rtazz17's Avatar
rtazz17
Sorry I think I know what you mean but could you dumb it down alittle for me? Lol
tdpower's Avatar
tdpower
There is a c clip to hold it in place. I would get a replacement. I used red locktite on exhaust side of turbo and blue on the compressor side.
Old Apr 21, 2011 | 04:44 PM
rtazz17's Avatar
rtazz17
I went to every napa around here and none had freeze plugs.. Went to a maching shop and got a freeze plug but said he never heard of one with a cclip....How hot are gases on exhaust side, my pyro shows up to 1200 on pre turbo tapped in manifold..
Old Apr 21, 2011 | 06:57 PM
rtazz17's Avatar
rtazz17
Is the freeze plug basically a compression fitting, meaning nothing is needed to lock in place?What about adding some jb weld to it before I tap it in.. I dont want it blowing out after 2 miles of driving...what are the exhaust temps?Post turbo?
Old Apr 21, 2011 | 08:58 PM
rocketman2440's Avatar
rocketman2440
The c clip is on the housing already from where you removed the rod. I just put some jb weld in there, and really caked it in there. It has held up fine for over 1000 miles.
Old Apr 21, 2011 | 09:07 PM
nhill2090's Avatar
nhill2090
I would throw some hi temp retaining compound in there.
rtazz17's Avatar
rtazz17
Ooooh, now I understand... Thanks thats the answer I needed to clarify...
Old Apr 22, 2011 | 06:49 AM
mtdigger's Avatar
mtdigger
Take the pedestal and freeze plug to your local muffler shop, give the guy a double sawbuck and have him weld it in
Old Apr 22, 2011 | 09:11 AM
white Buffalo's Avatar
white Buffalo
one option is just remove the old EBPV housing from the turbo and add one of these on:
Riffraff Diesel: Garrett High Flow Outlet.
don't forget to put a 470 ohm resistor in the harness to keep the engine code (soft) from showing up and possibly causing it to defuel. $1 at radio shack.
Old Apr 22, 2011 | 09:28 AM
rtazz17's Avatar
rtazz17
Yep I just saw that on clays site,I might do that with the delete pedestal.I have had the solenoid d/c for 5 days now with no defueling.I heard of the soft code which Im sure I have(I havent hooked up my a/e to verify)but didnt know about defueling??????guess Ill have to get the resistor if thats the case.I dont care about the soft code...Does anyone know if its worth getting a new collector to the back of turbo clamp?Im assuming I may damage it taking it off for the first time?
Old Apr 22, 2011 | 09:38 AM
rtazz17's Avatar
rtazz17
Is there a seal between the exhaust housing and turbo that needs to be replaced after putting a new high flow housing on?
Old Apr 22, 2011 | 09:46 AM
white Buffalo
I put the Garrett High flow outlet on my Excursion last week along with the Non-EBPV pedestal and rebuilt the turbo (got all the parts from Clay at Riffraff). The only seal I replaced was the one on the compressor housing. Check with Clay just to make 100% sure.
LongRider
Jun 20, 2013 12:22 AM
500FordF-150
Mar 10, 2011 07:58 PM
01 superduty
Apr 1, 2008 09:16 PM
Bigtrucknuts
19
May 2, 2006 05:57 AM
maticuno
1983 - 2012 Ranger & B-Series
Nov 21, 2003 07:37 PM
