Pulling stuck flathead V8
Old Apr 21, 2011 | 10:32 AM
cruisetopdown's Avatar
cruisetopdown
It's time to get serious and pull the stuck flathead. I have had it soaking with PB for several months with no luck getting it to free up, so I have decided to pull it so I can take it apart and do this the right way. My question is regarding the actual removal of the engine.....Can it be lifted high enough to clear the fenders (hood off of course), or does it require the removal of the front end bodywork?
As always, thanks for the advise.
Wade
Old Apr 21, 2011 | 10:51 AM
mtflat's Avatar
mtflat
Yes, but it depends on what you're lifting with. Standard cherrypicker will do it.
It is much easier however to remove the 12 bolts holding the front end on and lift it out of the way.
2 bolts at the bottom of the radiator support, 1 each side in the firewall seam, 2 each side in the fender, 1 each side in the deflector at the running board and some have one each side to the frame. iirc
Old Apr 21, 2011 | 11:47 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd check with your hoist closely first; to get down close to the block (short chain) your cherry picker's boom may not clear the front end. You want a good strong, stable picker if you're going to have 600 lbs that high in the air, and be rolling it around. Taking off the front wheels to lower the truck would help.
One thing I've always wanted to see tried on a stuck engine is putting hot water in it. It seems to me expanding the cylinders away from the pistons could do a lot more good than soaking, or maybe augment the penetrating oil's action. You'd probably have to add HW, drain after it cools, add more, etc. but it sure seems worth a try.
Old Apr 21, 2011 | 01:16 PM
cruisetopdown
I have a hf 2 ton picker, but am not sure if it will be strong enough to lift that high with the boom extended that far out. I also have a lift in the garage that I can use to lift it if I need to, but thought I would set the truck on the lift with no wheels and lowered to the ground, then cherry pick it. I don't really want to pull the front end as I don't have space for the parts inside (other projects) and don't want them sitting on the ground outside if I can help it.
w
Old Apr 21, 2011 | 01:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might get it out at a shorter boom extension coming in from the side. Any way you could use your lift, up in the air, with a chainfall down to the engine? (depends what kind of lift it is)
Old Apr 21, 2011 | 02:55 PM
52 5 star's Avatar
52 5 star
I pulled mine withjust the front grill and radiator and its support and exhaust mainfolds removed. It fit right between the fenders
Old Apr 21, 2011 | 03:34 PM
49fordpickumup's Avatar
49fordpickumup
When I disassembled my front end it was easy to remove after the bolts were removed. You can reinstall the front end on the truck after engine removal, no extra space needed and you may want to paint the engine bay, front frame etc. No chance of banging the fenders etc when removing the engine. Someone already mentioned swinging the engine around 5-6 feet off the ground. I can just see a hoist losing pressure in the pump. I had several of the chinese shop tools purchased after a tool show in Houston. They lasted until the first time they started leaking fluid and you couldn't find parts,about 6-8 months, especially "o" rings to reseal the pumps. Be safe, chuck
Old Apr 21, 2011 | 03:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
My HF cherry picker almost folded over when a 200" Ford 6-cyl got off-center, trying to lift it clear of the radiator on a Maverick. It's the 2-ton folding-leg model. After that incident I welded reinforcements on it, but it leaks down slowly and as Chuck says, no spares are available. On any engine with any lift, my policy is to make the load as light as possible, pull off the intake, starter, generator/alternator, anything to keep it light.
BTW, here are some good lifting tips for a flattie.
https://www.ford-trucks.com/forums/8...r-removal.html
https://www.ford-trucks.com/forums/7...nd-tranny.html
I like RCAV8OR's lift plate the best, you can duplicate it with 2 @ 3"x3"x1/4" angle irons and a 1/2" bolt between them for the hook.
jreilly57
17
Feb 12, 2016 05:18 PM
Marauder2004
33
Sep 10, 2014 09:41 AM
Kyles Flathead
19
Feb 22, 2012 10:44 PM
badger_hound
Nov 22, 2011 09:37 AM
F7-LaFrance
Flathead V8 & Flathead 6
Jan 21, 2005 03:10 PM
