RPM spike
Old Apr 21, 2011 | 09:47 AM
tshrager's Avatar
tshrager
RPM spike
Truck just started doing this. While driving on the freeway, at 65 and going up a slight hill, I'll lean into the throttle a hair to keep it at 65. Normally the truck is at about 2100 RPM at these speeds and motors right up them. Yesterday and today, it will jump 200-300 RPM like its down shifting, but it's not. I'm not too worried about this, but if there is a problem here, I would like to address it as soon as possible. Anyone heard or have any experience with this? Thanks for the input, Todd
Old Apr 21, 2011 | 09:52 AM
Talyn's Avatar
Talyn
TC unlocking?
Is there any feel of loss of momentum for a moment?
No gauges, so you cannot watch boost and EGT's to see whats going on.
Old Apr 21, 2011 | 09:56 AM
250turbo's Avatar
250turbo
think your torque converter unlocked.
Old Apr 21, 2011 | 11:41 AM
makomark's Avatar
makomark
A single RPM jump with the throttle activation that returns to 'normal' when the pedal does sounds like the converter unlocking to me as well.
Old Apr 21, 2011 | 03:23 PM
tshrager's Avatar
tshrager
Does this mean the TC is going and needs replaced?
Old Apr 21, 2011 | 03:42 PM
MADVAN's Avatar
MADVAN
Remove icp mod and test run.
B
Old Apr 21, 2011 | 04:03 PM
tshrager's Avatar
tshrager
Ok. Its parked for the evening, but I'm going to drive it tomorrow with the ICP mod still in and make sure I'm not crazy. It didn't do it on the way home from work. If its acting up, I'll remove and test. I did notice it once or twice this winter before the mod and it went away until now. Fluid level was 3/4 full on the hot mark with a few bubbles. Thanks for the help guys
Old Apr 21, 2011 | 11:24 PM
oldbird1965's Avatar
oldbird1965
Maybe the clutch disks in the trans are slipping, needs rebuilt.
Or, somehow the brake is activited which unlocks the TC.
Old Apr 22, 2011 | 07:47 AM
RRranch's Avatar
RRranch
There are a LOT of things that can make the TC unlock when it's not supposed to. 2 shops told me my kids E4OD was fried and it was far from it. One problem was the solenoid pack was bad, the other was the TP sensor was misadjusted and THEN the RPM sensor wires shorted together. It kept throwing code 62 which doesn't tell you much except that the TC is slipping. That code puts it in limp home mode.
Don't condemn the TC or transmission till you've diagnosed it properly. That's all I'm saying. My kids is a 93 IDI and sat for several years with mice and other critters chewing on stuff underneath but it's running great now! Just took a while to catch and fix all the little problems.
Old Apr 22, 2011 | 08:41 AM
tshrager's Avatar
tshrager
It was doing it again this morning. If removing the ICP mod doesn't work, what should be my next course of action? I'm supposed to take it camping next weekend and don't want to be stranded with my yuppie buddies that know nothing about trucks and like to give me a hard time for driving a 15 yr old truck.
Old Apr 22, 2011 | 08:53 AM
MADVAN's Avatar
MADVAN
Is it the tc unlocking or is it a downshift from od?
Does the od lamp work?
You have to give better info on your issue.
It could be something simple or not.
1 step at a time or bring it to a trans shop.
B
Old Apr 22, 2011 | 09:06 AM
tshrager's Avatar
tshrager
The TC is unlocking. OD light is working properly. I thought it was shifting out of OD at first, but when I took it out of OD, the rpm jumped a lot. Im 98% sure it's the TC unlocking at speed. It won't do it on side streets
Old Apr 22, 2011 | 09:45 AM
tshrager's Avatar
tshrager
After doing some more research, intermittent problems after warming up points to solenoid. Found them on eBay reman for 100
Old Apr 22, 2011 | 05:56 PM
tshrager's Avatar
tshrager
I'm thinking of doing the solenoid and possibly a racer X valve body, new filter and fluid. What do you guys think?
Old Apr 23, 2011 | 12:46 AM
oldbird1965
I have a TC lock switch. Its just a simple toggle switch where you can ground the wire by the trans and keep the TC locked. I mention this for testing purposes. The wire is pink, purple, I can't remember. I can look if you want.
