How to tow?
Old Apr 20, 2011 | 11:26 PM
David Gordon's Avatar
David Gordon
How to tow?
I took my boat to service about a 100 mile run. Boat and trailer weigh about 6k+. The truck never acknowaledged the trailer was there. What do I have to do to use trailer brake and such. It kept showing No trailer.
Old Apr 20, 2011 | 11:40 PM
kper05's Avatar
kper05
Is your trailer plug a 7-pin?
Something that heavy should be.
Old Apr 21, 2011 | 03:51 AM
mr176's Avatar
mr176
Most boat trailers use hydraulic surge brakes rather than electric brakes. I think the truck will only recognize trailers with brakes that require electric activation (electric or electric over hydraulic). Surge brakes do not require a controller.
Old Apr 21, 2011 | 07:04 AM
Champ198's Avatar
Champ198
Agree. My 21ft bass boat has hydraulic surge brakes. It needs the 5 wires (has the reverse to diasble the brake lockout) and I use the 7 pin RV plug adapter.
EpicCowlick's Avatar
EpicCowlick
If you've already checked all the fuses, just run the truck and trailer down to a local trailer supply or RV dealer and ask them to help you you. It should be a simple wiring issue.
Old Apr 21, 2011 | 08:17 AM
David Gordon
Thanks, yes it is a 7 pin. It is a 26' boat and i do believe the trailer is surge.
Old Apr 21, 2011 | 09:49 AM
lakedweller's Avatar
lakedweller
+1 I would think it would only tell you that you have a trailer that would require it's electric brakes controlled. How could it see a trailer with only the lights connected and on the class 5 hitch????
Old Apr 21, 2011 | 11:05 AM
cirrus365's Avatar
cirrus365
I had a similar issue and it ended up being a bad ground on the trailer.
Old Apr 21, 2011 | 12:52 PM
6.7Fan's Avatar
6.7Fan
I had the same thing taking my boat in for service. I just assumed it was the trailer type. However, it would be nice to see it to track the miles on the trailor. So should it show the trailer no mater the connection type?
Old Apr 22, 2011 | 03:34 AM
TheKid1's Avatar
TheKid1
The 7 pin connector on my travel trailer didn't make contact with my 2011 f350 initially. A little lube on the outside and goes right in, connection made!
js139
All Things Towing
20
Jan 17, 2018 08:34 PM
northernsnooker
Jul 27, 2016 04:47 PM
-Jim G
16
May 3, 2009 05:52 AM
jake00
All Things Towing
19
Aug 22, 2007 11:13 PM
erics
15
Sep 14, 2000 10:54 PM
