I want to ask what its clogged with... but a little oxy acetelyne in the back side, and light it off, that'll help blow it out.
Maybe put it on backwards?
For a cat to fill up, its either never hit operating temps or something is leaking into your exhaust and sludging it up.
I'm not sure what clogged it up but As soon as I disconnected it from the downpipe I could build boost. At first I just unbolted it from downpipe and drove it around it was still in line with the downpipe but just that alone was enough for my boost gauge to move off "0". So the next day I planned to remove the whole thing started to unbolt the back end and bolt on the clamp broke off. So I cut almost threw all but the top part of the back end. Took it around the block and now boost was back where it should be but very loud.
Putting on backwards that works, I didn't know that. I'm thinking I need to educate myself on how the converter works.
I would take you up on that except you are in Texas and I'm Cali. It would take to long for shipping. I can buy a new somewhere, right? Hopefully I can fix the one I have though
Converters generally don't care on direction, just a series of small tubes but yeah, I'm wondering what happened to it that caused this problem. Find a straight section near the cat, give yourself an inch or two and you can use the full wrap truck exhaust band clamps to put it back in place. Most of your driving around town? any oil consumption? seems like there must be a malfunction someplace.
I cut the converter piece about 3" back from where the cat connects to the muffler. Actually it's still on the truck, the whole catalytic convertor, I've cut all but the very top of the piece. Not sure if that gives me any other options
Do you mean forward of where it connects to the muffler? Back doesn't make sense. Anyway, you definitely cut the one-piece cat section and not the short piece behind it?
I will say my 99 7.3 seems to run cleaner after a 4500 mile weekend, half towing a trailer and seeing darned near 1200 degrees when climbing the big hills at speed and just a nick under 20 psi. Normally it puts around town with me keeping the EGT under 700
I bought the truck with 175,000 miles on it about 16 months ago. It has an under belly Tow lift on it. Used for Repossessing cars. So there has been a lot of driving around town, stopping, and towing. It hasn't burned oil since I've owned it. Ficm was bad a few months ago and would smoke a lot when I started it but other than that hasn't smoke at all.
Just went out and looked yes it's the one-piece cat-section
Ok, then I would gut it and weld the part you cut, or find a replacement on craigslist and gut that. Some guys run a delete pipe, but I would want mine to look stock just in case.
Thinking further, I bet you could take it out and blow it back through with a pressure washer, I bet a city wrecker had a million hours of idiling and never ever got up to temps needed to clear out. Rather doubt water would bother it. skip the hot wax
Don't do this you'll just plug it up more (soot + water = paste) don't make a 'bomb' out of it either as previously mentioned, post explosive gasses (the force) always seeks the path of lowest resistance i.e. through the open ends not through the catalyst. Just knock the whole catalyst comb out of the cat with a bar and hammer and bolt/weld it back on. People have been gutting cats since the day they were put onto cars... Here's a tutorial: http://www.ehow.com/how_4720012_punc...converter.html
I like bombs, and you can't do ignition backfires with fuel injection.
I was thinking if the pipe section was cut free, stood on end and then just rip it clean with a pressure washer. Should work great for flushing it out. I dunno, I don't think my cat is holding me back at all. It tows, it boosts, it scoots, thats what I need.
I like bombs, and you can't do ignition backfires with fuel injection. .
I guess I wasn't clear enough. You said:
Hence my bomb reference... But I would love to see somebody actually do this.
Side note: It's very easy to get a fuel injection system to backfire but I don't know why you brought that up...?
Your pressure washer idea isn't a bad idea. I just think it'll make a bigger mess than simply knocking the comb out of the cat and being done with it once and for all. Soot and water is a bitch to clean up unless you have ethanol or the like to aide in cleaning.
Just wanted to update this thread. I ended up gutting my cat. It didn't look that bad some black inside the honey comb but that is to be expected. I took it down to a muffler shop to have the piece welded back on. The guy there suggested replacing the muffler, says that a clogged muffler could create the no boost situation. Decided for $200 might as well. So in the end I don't know if the problem was from the cat or the muffler but it's running great finally. Thanks you all for the great advise.
Rather than splitting it open, just knock all the guts out with a long bar, called "gutting the cat" and put it back on. It will look stock in case you ever get a visual inspection ($10k federal fine to remove emissions equipment). Some people say you get weird drones, so if that's an issue you can shove a straight pipe through it.
Even for cat's? I thought it was a DPF only thing.
