98 Navi sputtering
Old Apr 19, 2011 | 06:37 PM
waldosnavi's Avatar
waldosnavi
Unhappy 98 Navi sputtering
Hi guys and gals, have a question. I am out of town right now and my check eng. light came on before I left. Brought it to auto zone and it came out with 2 codes (dont remember right now because i am out of town) any way, the guy at auto zone said he thought it was the MAF sensor because of the codes. I took it apart and cleaned it good, reinstalled it and still had the light. Now the wifey is using it and it starts to sputter at the lights while brake is on and wants to die on her. Any ideas so I can fix when i get home? will it leave here stranded with the kiddos? Thanks guys. Oh ya its a 98 Navi 4x4 with 158K
Old Apr 19, 2011 | 07:18 PM
dan4147's Avatar
dan4147
No posts so far huh. Hope you get home and use this site for help when you have the codes. You can use search and get a ton of info. I can at least make a recommendation since there are kids involved and you are away. Have your wife put a wrench in the Navi to fit the negative battery cable. Worst case if it dies pull over and take the batt cable off for a few minutes. This is a possible bad situation and not good as she will have no power steering or much brakes if it quits.
Old Apr 19, 2011 | 09:14 PM
waldosnavi's Avatar
waldosnavi
very true, she parked it and is using my truck now. Dont feel safe her driving it at least till I get back home.
Old Apr 20, 2011 | 01:38 PM
TreeA10's Avatar
TreeA10
Had a similar problem and do not remember the exact code. There is a line that connects the PCV valve to the back of the throttle body. The line is attached to the back of the throttle body by a 90 degree rubber elbow. The inside of that elbow was ripped allowing a vacuum leak which was causing my problem. I could not find just the elbow so I ended up buying a new PCV line with the elbow from Ford for about $50.
Old Apr 20, 2011 | 02:53 PM
Moto Mel's Avatar
Moto Mel
An 8mm wrench is needed for the battery cable and a 90* spark plug boot will fit the tube for the vacuum, I believe.
Ford could have saved the world a lot of trouble by just installing a 90* elbow in that vacuum port when the truck was built. It might have cost an additional 3/10 of a cent, but the bean counters might have had a fit over the increased cost.
gddyup
Mar 11, 2014 02:10 PM
dirtsnow
Nov 15, 2007 01:36 AM
forddriver71
Oct 10, 2006 03:45 PM
ntune
Modular V8 (4.6L, 5.4L)
Sep 3, 2005 10:11 AM
ckstrawser
17
Dec 7, 2004 11:39 PM
